Measuring Angles - Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 12-26-2010, 08:15 PM   #1
measuring angles - flooring
How do I measure angles on laminate flooring?
felicity7 is offline   Reply With Quote
Old 12-27-2010, 01:58 PM   #2
Handyman
Rewards Points: 512
Need more info but I am assuming you are flooring up to an angled wall or threshold. Easiest way is to lay your plank parallel to the rest of the flooring and butting up against the wall. Take a straight, wide piece of wood and place it along the wall or threshold. When you cut that scrap piece you will have created a template for cutting the rest.
canadaclub is offline   Reply With Quote
Old 12-27-2010, 05:30 PM   #3
Rewards Points: 200
Pick up a Bevil square at the local HD for a couple of bucks.
Floor Doc is offline   Reply With Quote
Old 12-29-2010, 07:33 AM   #4
KCB
you can use cardboard pieces cut with a nice razor to test a cut before you waiste the wood
KCB is offline   Reply With Quote
Flooring for hot tub room with tongue and groove base flooring. tkmiller Flooring 0 10-24-2010 01:21 PM
Installing Hardwood Flooring on Concrete Flooring, Condo slickwilly789 Flooring 1 10-08-2010 09:53 PM
Strange engineered wood flooring install in Philippines (pics) Flt_Simulation Flooring 7 10-05-2009 10:00 AM
Installing engineered flooring in the Philippines Flt_Simulation Flooring 15 07-21-2009 09:00 PM
no glue, no nails wood flooring - little help? reds_21 Flooring 2 02-13-2009 12:32 PM
