-   -   measuring angles - flooring (http://www.diychatroom.com/f5/measuring-angles-flooring-90483/)
felicity7 12-26-2010 07:15 PM
How do I measure angles on laminate flooring?
canadaclub 12-27-2010 12:58 PM
Need more info but I am assuming you are flooring up to an angled wall or threshold. Easiest way is to lay your plank parallel to the rest of the flooring and butting up against the wall. Take a straight, wide piece of wood and place it along the wall or threshold. When you cut that scrap piece you will have created a template for cutting the rest.
Floor Doc 12-27-2010 04:30 PM
Pick up a Bevil square at the local HD for a couple of bucks.
KCB 12-29-2010 06:33 AM
you can use cardboard pieces cut with a nice razor to test a cut before you waiste the wood :)
