Old 02-18-2011, 03:30 PM   #1
Mats on vinyl flooring
I read somewhere that you should not put rubber-backed mats on vinyl flooring. In particular, they were referring to Allure flooring. Does anyone know if this means that one should avoid placing rubber containers or boot trays on the flooring, as well?
Rayma is offline   Reply With Quote
Old 02-18-2011, 04:24 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Plasticizers are chemicals added to plastics, vinyl, and rubber to make them softer and more flexible. The softer or more flexible the material, the more plasticizer it contains. Since rubber mats are fairly flexible, they contain a lot of plasticizer. Over time, the plasticizers migrate out of the rubber or plastic and are absorbed into surrounding materials. They tend to stain. It's called "plasticizer migration".
"I'm twisted, not sick. Sick implies, I'll get better"
Semi-Retired Installer
Installing since 1973
The Following User Says Thank You to rusty baker For This Useful Post:
Rayma (02-18-2011)
Thin set vs mesh porcelain floor tile over plywood subfloor and vinyl flooring Jerseygirl Tiling, ceramics, marble 48 05-14-2013 10:43 PM
No glue vinyl flooring in a wide room? BizeeB Flooring 1 11-23-2010 09:50 AM
Ripping up Vinyl Flooring harmony Flooring 5 02-26-2008 05:50 PM
Sheet Vinyl Flooring Removal yoods Flooring 2 11-22-2007 01:04 PM
Can I cover old cracked vinyl flooring with lauan and new vinyl? MikeC. Flooring 4 03-12-2007 06:20 AM
