Old 10-20-2009, 06:04 PM   #1
Default matching up 1/2" hardwood floor to 1" tall tile
Just installed new tile in kitchen. Now getting ready to put hardwood flooring in family room, but my tile is about 1" above the 1" thick sublfoor and my hardwood is only 1/2" thick. I want the tile and the hardwood to appear to be at the same height. I was thinking of laying 1/2" plywood on top of the sub floor to match heights, but I don't want to lay 500 SF of plywood just to match up 12 feet of transition. I saw this article (
http://www.hardwoodinstaller.com/hardwoodinstaller/wood-subfloor-prep.htm) about shimming the hardwood with tar paper to get even transitions. Does this work? How far out do you need to lay the tar paper? Are there any step by step instructions on the internet on how to do this? Any other ideas?
Thanks for any info
Chris
cmlcsu is offline   Reply With Quote
Old 10-20-2009, 08:19 PM   #2
Shimming with tar paper is only for small dips in the floor. You would have to lay out the plywood as you had thought. Transition strips, both factory made and fabricated on site deal with this kind of an issue. You should allow a gap between the tile and the wood floor to allow the wood floor movement. A transition strip will help deal with this as well.
Josh Jaros Remodeling in The Woodlands, Texas www.jarosbros.com
jaros bros. is offline   Reply With Quote
Old 10-20-2009, 08:47 PM   #3
In my opinion 1/2" is too much to deal with the tar paper shimming or even a threshold. My vote would be to spend the money and time by adding the 500 sf of subfloor.
Nothing better than a flat transition to make it look like a real pro job. Bad pic I know but you get the idea.
Cheers, Rod
derf36 is offline   Reply With Quote
Old 10-20-2009, 10:56 PM   #4
what is the limit for height change for the tar paper?
Tags
hardwood to tile, transitions
More On This Topic
Vinyl tiles are one of the most commonly used floor coverings in homes today. The flooring comes in a variety of colors, textures and styles. Vinyl tiles are durable, decorative and easy to maintain. Follow the steps below to keep your vinyl floor in... Read More »
Spanish tile has been used for centuries on roofs, and some of these old, historical roofs are still in existence. There are times when repairing a Spanish tile is necessary. Read this eHow to learn more. Read More »
If you're looking for carpeting you can install yourself consider carpet made in tiles of varying sizes. The major benefit of carpet tiles is the ability to replace only 1 or 2 tiles if staining occurs, while leaving the rest of the carpet intact. Follow... Read More »
In this segment I'm going to talk to talk to you about how to bounce a ball. As you can see I'm on tile today and it's a little tricky cause it has cracks in it. So I really want to practice right in the middle but if you're on hardwood floor or linoleum... Read More »
We're talking about a variety of hand tools and stuff that we're using on the job sites. One of the most important tools is a pencil. It's one of the first tools that you want to break out. Me, I like a big pencil cause when I make a mistake, I make them... Read More »
Hardwood transition to ceramic tile willyberger Flooring 5 08-09-2009 01:38 PM
Tile over Oak Hardwood floors (unfinished) irishgem@ymail. Flooring 3 07-13-2009 11:07 AM
Hardwood floors installed over 1/2" and 5/8" subfloor interplexr Flooring 1 01-25-2009 03:00 PM
tile over hardwood floors MnMan Flooring 1 07-30-2008 07:39 PM
Hardwood and Tile Transition Gap mobowhunter Flooring 2 01-19-2008 07:25 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
