#1 |
Matching timber flooring
This is the timber flooring in the sunroom and, as far as I know, it is also the same under the carpet in the bedrooms and hallway of the 'old' section. The 'new' added on part of the house has vinyl and carpet which I want to replace with timber flooring.
Any idea what type of wood this is? (And I am in Australia )![]()
#2 |
Hard to tell since I don't know what is common down under. It has lots of knots suggesting it is from a softer, faster growing conifer rather than a hardwood species of tree. Hopefully someone nearer you will chime in.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#3 |
My bet would be Murray Pine or what American's call Australian Cypress. It was very popular in post WWII bungalows.
http://www.timber.net.au/index.php/species.html I have a farm house in the Southern Highlands with Murray Pine floors. Last edited by goosebarry; 07-10-2012 at 11:40 PM. |
#4 |
Great link!
Thanks Goosebarry (Funny. Thats what I call my husband sometimes )
#5 |
Floor coatings have a life span, you will not be able to match the stain as the old stain has faded , and it would take as specialist supplier to have the stain matched.
I would sand the floor back to a point where the join will be in shadow, then stain and coat. do you know if the floor coating is water based or solvent based?? and also the brand & type?? Not all brands are compatible , so this information is critical. Semi Solid Wood Flooring |
#6 |
Jastin I am not trying to match the stain. Obviously the floor in the pictures will be stripped back and redone.
I am trying to match the wood - as best I can. What I want to try and do is match new timber flooring with this old stuff. |
#7 |
The flooring does appear to be cypress. However, it is hard to tell for sure.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#8 |
I ran across this website. http://www.walkerbros.com.au/contact_us.htm. They appear to be near you. The family might have even built the original floor.
| Display Modes | |
| can anyone help with Timber Tech flooring price? | dbldee20 | General Discussion | 3 | 04-25-2012 09:15 AM |
| Making hardwood flooring from rough-sawn timber | frank s | Flooring | 1 | 01-06-2011 02:37 PM |
| Installing engineered flooring in the Philippines | Flt_Simulation | Flooring | 15 | 07-21-2009 09:00 PM |
| Laminate timber flooring over exsisting slate | scott10 | Flooring | 6 | 06-20-2008 05:04 PM |
| All about flooring – wooden floors (part 1) | abraun | Flooring | 8 | 04-28-2008 11:46 AM |
