Marble Threshold Question - Flooring - DIY Chatroom Home Improvement Forum
Old 06-20-2009, 06:30 PM   #1
They're all fixer-uppers
J187's Avatar
Rewards Points: 516
Marble threshold question
I could have sworn I posted in this already, but it seems to be gone...
anyway..
I am using a marble threshold in my bathroom. How wide should the threshold be, should it extend to the rough opening studs on each side of the door and the door sit ontop, or should it stop on each side where the door jambs will be? Then the door just goes on top and whereever I have to cut the door to make it sit level, I do?
J187 is offline   Reply With Quote
Old 06-21-2009, 07:09 AM   #2
They typically are the width of the wall, usually 4".
Old 06-21-2009, 08:30 AM   #3
J187's Avatar
Rewards Points: 516
Thanks.. I guess I mean length. What I am asking is do I run the marble before the door goes in, to the edges of both rough studs...in other words, does it span the whole width of the rough opening?
Old 06-21-2009, 09:35 PM   #4
Tileguy
JazMan's Avatar
Rewards Points: 422
Actually modern walls are 4.5" thick, have been since the '60's. Those that sell "real" marble threshold have them made 4.5" wide. For some unknown reason to me, the big box stores have them made 4" wide, I shake my head when I see them.
J,
I guess the jambs are not installed yet. Normally the threshold goes jamb-to-jamb. You can install the tile and threshold now, but you need to calculate how that changes the height and if the door will fit properly. You may end up with too much space under the door, all depends on tile installation method. On the other hand it may be better if you hold the jamb high. Be careful, doing so will make this door higher and will not look right with other nearby doors.....higher at the top I mean.
Jaz
Old 06-22-2009, 05:53 AM   #5
BUILDER / REMODELING CONT
buletbob's Avatar
Yes the Jazz-Man Is correct. I would install all my doors the same height this way all the trim heights are the same as viewing the tops. Remove the door stops on both sides and then install your door saddle, measure and cut your stops and install. then measure down from your door hinge to the saddle and subtract 1/4" and this is what you would cut down your door to. ( more if you are going to have a small rug by the door. also be prepared to plug the bottom of the door after you cut it down. Good luck BOB
Old 06-23-2009, 07:13 AM   #6
J187's Avatar
Rewards Points: 516
Thanks guys, the saddle I bought is 4.5" from a tile store. The door is not installed yet, I was thinking that would be one of the last things I do. I have a prehung unti waiting in the garage. Sounds like I will use the saddle temporarily in place to run my CBU and then tile, take the saddle out and put the door in. Take off the stoppers, put the saddle in and put back the stoppers
Old 06-23-2009, 09:14 PM   #7
Tileguy
JazMan's Avatar
Rewards Points: 422
The CBU goes under the threshold too you know?
Jaz
Hardwood closet threshold question DIY-Renovator Flooring 1 07-27-2008 04:42 AM
Marble Tile Question kidflash3002 Flooring 1 07-10-2008 06:49 PM
Marble Tile Question kidflash3002 Flooring 3 07-01-2008 07:09 PM
Threshold question LCangler Flooring 9 07-22-2007 03:57 PM
Installing Marble Threshold Redleg Flooring 3 10-21-2006 05:16 PM
