Old 11-10-2006, 11:07 PM   #1
Marble or Porcelain tile for main foyer?
Our main foyer has a lot of cracked tiles and we are having the subfloor repaired.
Should we put marble, shiny porcelain, or some other type of tile?
The look of the tile is very important since it is in the main foyer (1st thing you see when you walk in the front door), but I would imagine that you need a durable tile since it's a high traffic area.
Will marble still crack if the subfloor is fixed? I'd hate to go through this process again.
Any suggestions on where to get tile (both store and internet) would be appreciated!
Grayson73 is offline   Reply With Quote
Old 11-11-2006, 12:01 AM   #2
747
registered
747's Avatar
No unless there is deflection in the subfloor which you cant have with any marble or porcelain or granite tile. Just get the subfloored fixed and go with what you like. What is under the tile. Plywood? If it is there is your problem. It needs to be set on durarock (cementboard) Meaning plywood then durarock then tile. Where to get? Definately not the internet. Open yellow pages and find a tile warehouse or ask a interior designer in your area she would no for sure. Make sure they seal it after installation.
747 is offline   Reply With Quote
Old 11-11-2006, 12:10 PM   #3
Tileguy
If you are experiencing cracked tile then obviously there is a problem. What are you doing exactly to have the subfloor fixed?
How big is this area?
Is the subfloor wood or concrete?
If wood,
What is the size of the floor joists?
What style are the floor joists?
What is the spacing of the floor joists?
What is the unsupported span of the floor joists?
What is the subfloor made of and how thick is it?
What type of tile is there now and what tile adhesive was used originally?
Bud Cline is online now   Reply With Quote
Old 11-11-2006, 06:03 PM   #4
A contractor suggested to remove the tile put cement, then durarock, and then put marble or porcelain tiles. He wanted us to pick the tile so I wanted to know which I should pick. I don't want to pick Marble if it will break again.
Old 11-11-2006, 09:09 PM   #5
747
registered
747's Avatar
I think limestone tile is sharp. I also like granite tile. I don't really care for marble but that is just a personal preference. Don't worry about cracking because if he is going with cement than durarock there wont be any movement. Once again don't forget to tell installer you want the tile sealed.
Old 11-12-2006, 11:38 AM   #6
CBU doesn't do a thing to strengthen that floor, you need to answer Bud's questions, forget stone if that floor doesn't meet specs, you need to find out why the first floor failed, before continuing, or you'll be in the same mess again.
R&D Tile is offline   Reply With Quote
Old 11-12-2006, 03:20 PM   #7
Tileguy
Nothing could be further from the truth Grayson73, it's that kind of information that has allowed your existing floor to crack.
Now! Once again:
If wood,
Old 11-12-2006, 06:12 PM   #8
747
registered
747's Avatar
I was assuming that guy made sure it wasn't a structure problem before he recomended cement then durarock. But as Bud and R and D said make sure there isn't anything structural causing the tile problem in the past. Better have a carpenter come out and take a quick look just to be safe.
Old 11-12-2006, 07:54 PM   #9
Tileguy
If wood,
More On This Topic
What to Use for Subfloor
What to Use for Subfloor by Stephen G. Anthony
Subfloor is material that goes under flooring materials, and subfloor can be made out of medium-density fiberboard, concrete board and cement board. Use a subfloor material that will resist moisture with help from a professional carpenter, woodworker and... Read More »
Spanish tile has been used for centuries on roofs, and some of these old, historical roofs are still in existence. There are times when repairing a Spanish tile is necessary. Read this eHow to learn more. Read More »
Fox and Geese is a board game that uses marbles. The play is like a one-sided checker game, the fox can jump the geese but the geese can only take defensive measures and block the fox. When the fox jumps the geese they are out of the game. The geese can... Read More »
Buy pretreated wood to withstand weather related conditions for outdoor DIY (do-it-yourself) projects. Purchase lumber with tips from a home repairman in this free video on home improvements. Read More »
Find out about the tools you will need for home screen printing in this free video clip on fashion tips. Read More »
Can I install 12x12 porcelain tile on a shower wall or ceiling? dezigner80 Remodeling 6 09-15-2009 01:05 PM
Porcelain tile over linoleum. STEPHENWANGEL Remodeling 12 08-17-2007 10:46 AM
Porcelain Tile Installation Burat Flooring 6 06-30-2007 04:26 PM
Marble Tile Countertop? Sportbilly Remodeling 14 05-17-2007 01:01 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
