MAPEI Mapelastic AquaDefense? - Flooring - DIY Chatroom Home Improvement Forum
Old 03-08-2013, 11:46 PM   #1
Hello,
I'm almost ready to install 18" x 18"porcelain tile on bare slab in a small guest bath, about 30 sq. ft..
There is a <1/16" crack that runs across the slab in this room:
The plane across the crack is flat, and the slab is 20+ years old. The slab is on grade, and a plastic sheet test doesn't show any moisture problem.
I'll be using the Mapei Ultraflex LFT to set the tile. I don't want to use Ditra but I'm wondering if a coat of the Mapei Mapelastic would be in order?
Thanks in advance, as always.
clambake6 is offline   Reply With Quote
Old 03-09-2013, 03:20 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 288
I think that would be a very good plan.
Jaz
The Following User Says Thank You to JazMan For This Useful Post:
framer52 (03-09-2013)
Old 03-09-2013, 07:46 PM   #3
Great! Thank you for your response.
Mapei waterproofing for shower base Mypan Tiling, ceramics, marble 4 07-28-2011 09:22 PM
Mapei 975 or Mapei 980? noone Flooring 0 06-14-2011 04:01 PM
Schluter vs Mapei and Fibrerock vs cementboard minerreno Kitchen & Bath Remodeling 0 07-08-2010 11:50 AM
Use Mapei premix adhesive and grout in shower walls cpietsch Building & Construction 1 12-28-2008 01:03 PM
