Old 01-06-2011, 11:40 AM   #1
Making hardwood flooring from rough-sawn timber
Just joined the DIY forum today and I have a question for the experts out there.
I am making our own hardwood flooring from the trees cut down on our property, mostly white oak and some poplar and pine.
This is seasoned wood and has 9% moisture content.
The flooring will be installed on the first floor ( we have a full basement that is dry and also insulated in the ceiling of the basement).
What do you all suggest for a vapor barrier over 3/4 Advantech plywood?
I am doing tongue and groove and I need to know if it is necessary to make the tongue and groove on the end of the piece also.
Do you suggest relief cuts on the backs of the wood?
Appreciate your response. Anxious to get this project underway!
Thanks.
frank s is offline   Reply With Quote
Old 01-06-2011, 02:37 PM   #2
Super Moderator
Frank---I suggest that you post this next door at Woodworking Talk--Link at bottom of this page--
Post it in 'forestry and milling'----
Many of the millers make flooring--they will know all your answers--
I'll answer a few--Use 15# felt under the wood--VB and sound deadener--
Tongue ans grove is needed on all sides and ends--
Relief grooves are a very good idea--Mike--
Hardwood flooring cupping Brian Lewis Flooring 14 12-06-2010 03:19 PM
Subfloor flooring for hardwood (question) somaxim Flooring 0 11-11-2010 05:29 PM
rough sawn lumber for hardwood floors david1031 Flooring 1 01-10-2010 08:20 AM
Installing Prefinished Hardwood Flooring Around Kitchen Island bioman Flooring 4 03-25-2009 07:18 PM
Installing Help! hardwood flooring in Hot&Humid weather dvarga Flooring 7 08-08-2005 06:45 PM
