Making A Groove In 5/8 Tongue And Groove Bamboo Hardwood Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 01-16-2012, 02:43 PM   #1
making a groove in 5/8 tongue and groove bamboo hardwood floor
Hi all -
What tool(s) do you use to make a groove in the end of solid bamboo flooring planks so the tongue of the following board can slip into place?
CMC9
CMC9 is offline   Reply With Quote
Old 01-16-2012, 02:46 PM   #2
Missouri Bound's Avatar
Table saw with a rabbetting jig.
The Following User Says Thank You to Missouri Bound For This Useful Post:
CMC9 (01-16-2012)
Old 01-16-2012, 03:13 PM   #3
jschaben
Rewards Points: 502
I'm kind of a newbie and am having trouble visualizing such an animal. Can you post a pic??
url reference would work also.
John Schaben
"Where all think alike, no one is thinking very much"
jschaben is offline   Reply With Quote
Old 01-16-2012, 03:26 PM   #4
Civil Engineer
Rewards Points: 4,790
I would use a router table with a slot cutter, if I understand what you are trying to do.
Daniel Holzman is online now   Reply With Quote
Old 01-16-2012, 03:43 PM   #5
I need to re-create the groove in the end of the floor board so the tongue of the next board can slip in place. I am laying hardwood planks that butt into a stair nose board and go length ways across the room. In order to stagger the boards, I am cutting them and then I need to make a new groove.
Am I making more work than I need to? Is there a way to hand router these grooves or is a table the only way?
CMC9
Sorry, I don't have a picture
Old 01-16-2012, 04:18 PM   #6
jschaben
Rewards Points: 502
CMC9
You need a groove along the end of the flooring board. Can't imagine anything less safe than a table saw. Hand held router with one of these bits would be the way to go:
http://www.amanatool.com/bits-fv/45663.html
John Schaben
Old 01-16-2012, 05:41 PM   #7
table router, not table saw! Thanks for bit link.
cmc9
Old 01-16-2012, 06:45 PM   #8
jschaben
Rewards Points: 502
cmc9
Actually, depending on how long the board is. If more than about 3 ft I'd do it with a hand held router. The key is the top bearing slot cutting bit.
Thinking about it, it could be done with any bearing guided slot cutter, given a cutting diameter/bearing diameter combination that provides an adequate depth of cut. Just that my preference would be a top bearing bit.
John Schaben
Old 01-18-2012, 01:04 PM   #9
No hardware store near me carries 3/8 slot cutting bit. The best I can find will only groove bigger than 3/8. Is this a problem? The tongue would have more room in the groove....should I hunt down the 3/8 bit?
Old 01-18-2012, 02:03 PM   #10
jschaben
Rewards Points: 502
Just how much bigger?? Where are you looking? I'm sure I've seen slot cutters at Home Depot (Freud brand) in 1/4". You can get wider slots on multiple passes by adjusting the bit height. Depth is what kind of concerns me. You need the correct bit/bearing combination, although, you could probably trim the end of the tongue if it's close.
I'm afraid if you go much larger than 3/8 you could end up with a squeak there or what would feel like a loose board. Like I said in my previous post, top bearing is really just a personal preference, bearing on either end would do it. Top bearing is only mandatory if you are doing repair work or some other reason to slot partially installed flooring.
John Schaben
Old 01-18-2012, 03:48 PM   #11
This is exactly what I needed to know - thank you - super helpful.
CMC9
can i install hardie board directly over tongue and groove sub floor? kleehammer11 Flooring 6 11-09-2011 06:06 AM
large, soft areas in newly laid tongue & groove floating floor dfeigin Flooring 0 08-15-2011 01:19 AM
Wood floor on a tongue & groove subfloor. Huckleberry Flooring 4 05-10-2011 08:41 PM
Replacing tongue in groove with support below odonata3 Flooring 0 10-20-2010 10:40 AM
planning on floating engineered floor tongue and groove imompero Flooring 7 10-05-2009 12:37 AM
