Making Floor Heights Easy - Flooring - DIY Chatroom Home Improvement Forum
Old 09-30-2009, 11:55 PM   #1
making floor heights easy
i have vinyl in my kitchen and i want to put down tile.The problem is the vinyl joins onto my dinning room and thats a wooden floor.The 2 floors are even and separated by a wooden divider which is good.
My question is can i put durock over the vinyl and tile it? but then it will be at least3/4 above the wooden floor and that would make people trip.
I dont think i can take up the subfloor because i would be on the floor joists and i dont think the durock would be strong enough.The floor joists are 16" off center.
Is there something i can put as a divider or whatever its calledto make the 2 floors just blend in so no one trips over?
thx
ron0805 is offline   Reply With Quote
Old 10-01-2009, 05:37 AM   #2
Remodeling Contractor
you will need to remove the vinyl and the 1/4" underlayment that would most likely be used. Then use Ditra and not cement board to keep the heights closer. This small difference will not create a trip hazard.
Thinking about making concrete pavers - a few questions Luis C. Building & Construction 16 06-10-2011 05:45 PM
Can anyone help a newbie? - Help with making a book case cosmicmeeting Carpentry 15 05-05-2011 11:39 AM
Pilot light going out often...and furnace making a big "boom" sound Beth777 HVAC 20 01-22-2011 04:27 PM
Making bear totum pole Keith of Ronin Landscaping & Lawn Care 2 03-27-2005 01:22 PM
