Makeing Wood Filler - Flooring - DIY Chatroom Home Improvement Forum
Old 03-02-2013, 02:47 PM   #1
makeing wood filler
how do i make wood filler with sanding dust for hardwood floors
mjkcontractors is offline   Reply With Quote
Old 03-02-2013, 03:12 PM   #2
Civil Engineer
Rewards Points: 4,956
Just mix the dust with approximately an equal amount of aliphatic (yellow) wood glue, press it in place, let it dry, sand.
Old 03-02-2013, 03:42 PM   #3
Rewards Points: 14,312
Going to look like poop and may do one of two things, crack when the humidy changes or cause the wood to "tent" or crush.
Old 03-02-2013, 04:44 PM   #4
Civil Engineer
Joe, I have had excellent experience with this technique. It was recommended by none other than Tage Frid, one of the premier masters of woodworking. As long as you have a sufficient amount of dust (not chips, dust) in the glue, and you are not trying to match grain, the patch is just as good as Minwax or similar materials. If you need to match grain, then you need a different technique like a plug , painted on lines, or use of marquetry. But for small holes in hardwood floors, such as nail holes, this technique works very nicely.
Old 03-02-2013, 11:55 PM   #5
Your right Dan, I was picturing that floor that was posted the other day with the huge gaps in in it.
Is this normal??? Exposed wood near foundation of house? simiesue Building & Construction 19 01-04-2012 10:01 PM
Ext Paint for Interior Application? PaoloM Painting 24 04-21-2009 04:30 AM
Amber Colored Wood Filler to Match Oak Steps MrBill_DIY Flooring 2 11-15-2008 07:31 PM
DAP caulking question n0c7 Painting 16 10-31-2008 11:31 PM
