Machines To Remove Linoleum Glue. - Flooring - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By joecaption
Old 08-07-2016, 11:08 AM   #1
Rewards Points: 18
Machines to remove linoleum glue.
Hey team,
I've removed all the linoleum across my entire house. And as you might have guessed, the glue is still of course all over the place. It's roughly 2500 sq. ft. of area to have completely cleaned so that I may stain the concrete in the coming weeks.
To do this, I've heard of many chemicals that can help. These range from simple soap and water to specialized adhesive removers. However, I'm unsure of which type of machine to use to help me out with this job. I'll be renting from Home Depot, and I was wondering if I should rent a 'Floor Polisher' or 'Floor Sander'.
The answer may be obvious, but if I sand the floor can it damage my concrete foundation and cause deep scratches? It looks like Home Depot even offers 'Floor Strippers', but I think those are just to remove the linoleum and not the glue?
Maybe order a Floor Polisher and attach it with one of these?:
http://www6.homedepot.com/tool-truck...569/index.html
Any help would be awesome, thanks guys.
MKMaster is offline   Reply With Quote
Old 08-07-2016, 11:35 AM   #2
Rewards Points: 13,228
Re: Machines to remove linoleum glue.
Time for a plan B on what to put down on that floor.
Even if you scraped off all the old glue on the surface there's still going to be some in the pores.
Stain is just that, it needs to be able to soak in to work.
You'll end up with a blotchy finish, and some will just rub off where it floats instead of soaking in.
Bud9051 likes this.
Old 08-07-2016, 01:37 PM   #3
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 38
Joe is exactly right.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 08-07-2016, 09:13 PM   #4
Rewards Points: 148
I noticed that they have scraper blades for sawzall/reciprocating saws, saw them at Lowe's last week. Might be worth a try if you already have the saw.
ChuckF. is offline   Reply With Quote
Old 08-07-2016, 09:32 PM   #5
All that would do is get off the high places, which is fine if your prepping for a tile floor.
HELP NEEDED!!! - How to Remove Glue from a Concrete Slab tclenn Flooring 10 06-29-2012 07:22 AM
20x20 Porcelain Tile over Linoleum on Concrete Slab scbauer Tiling, ceramics, marble 3 08-31-2010 08:11 PM
Tile Baseboard on outside of plastic shower pan at linoleum joint? GaryS Tiling, ceramics, marble 2 07-26-2009 01:39 PM
How to remove super glue from a painted surface? pip General DIY Discussions 5 07-01-2009 11:53 AM
Removing old carpet, left over glue...best way to remove it? RyanD General DIY Discussions 5 06-24-2009 05:37 PM
