Luxury Vinyl Plank Flooring - Laying Over Particle Board Subfloor - Flooring - DIY Chatroom Home Improvement Forum
Old 10-25-2013, 06:24 PM   #1
Rewards Points: 209
Luxury vinyl plank flooring - laying over particle board subfloor
Hi in my condo I have a fairly sound particle board subfloor.
I was thinking of installing "Allure -Ultra", "engage- select plank", or "Coretec -plus". Vinyl plank over it.
They're 5 mm, 5 mm, and 8mm gauge thickness
They all have lifetime residential /10yr commercial warranties
Does anyone know about these brands?
Would you recommend these over particle board subfloor?
The subfloor feels pretty sound and hard and only has >1/8 gaps between different particle boards. Some have carpet staples which I could either remove or hammer down level.
Could I possibly floor prep or even paint the floors to prep them for this?
Any other tips or experience would be great.
Pic below is of particle board under lifted carpet
crayola110 is offline   Reply With Quote
Old 10-25-2013, 06:53 PM   #2
Rewards Points: 13,256
Particle board is not a suitable subfloor for anything.
It's amazing to me it's even sold any more.
It soaks up moisture like a sponge and swells up with just a change in humidly.
Get's wet once and it turns to oatmeal and swells up to twice it's size.
Will it work? It's nothing I'd want in my house.
The Following 2 Users Say Thank You to joecaption For This Useful Post:
crayola110 (10-26-2013), Live_Oak (10-26-2013)
Old 10-25-2013, 08:25 PM   #3
woodman58's Avatar
All that said, it will work.
I LOVE THE SMELL OF SAWDUST IN THE MORNING!
woodman58 is offline   Reply With Quote
The Following User Says Thank You to woodman58 For This Useful Post:
Old 10-25-2013, 10:08 PM   #4
Rewards Points: 209
Thanks,
Is there anything I could do to make the particle board stronger? Like paint something onto it?
I'm in Los Angeles so humidity is low. I assume if I had a leak or burst pipe the Vinyl Plank would keep the particle board dry?
Old 10-26-2013, 12:04 AM   #5
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 42
Originally Posted by crayola110 View Post
Thanks,
No, it would not.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
The Following User Says Thank You to rusty baker For This Useful Post:
Old 10-26-2013, 10:27 AM   #6
K&B Designer
Live_Oak's Avatar
The right way to do it is to remove the particle board and put down a suitable subfloor. As previously mentioned, just humidity along (you can't tell me it never rains there!) will cause problems with the particle board. Just a bit of swelling at the seams (very common) will telegraph through the vinyl. If you had a leak, well, you'd have to remove the vinyl, then remove the swollen and moldy particle board anyway.
Do it right from the beginning if you only want to do the job once. It'll be cheaper in the long term.
Live_Oak is offline   Reply With Quote
The Following User Says Thank You to Live_Oak For This Useful Post:
Old 10-26-2013, 02:09 PM   #7
Rewards Points: 209
I see, thank you for all the advice. So I guess I'll have to remove all this board, making this a much larger project then I thought . It runs throughout 650 square feet.
Underneath the particle board is I believe 2x4s that run diagonally. They have larger 1/4 inch gaps between them. It's on the first floor of a raised foundation.
So would Plywood be suitable? Or is there something else you would recommend.
Old 10-26-2013, 03:47 PM   #8
Highly unlikely it 2 X 4's.
I would use Advantech not plywood.
Construction on top of the joist and 8D ring shank nails every 6".
Going to need a Toe Kick saw or sawsall with a short wide blade to cut the flooring out where it runs under the walls.
Old 10-27-2013, 02:06 PM   #9
Rewards Points: 209
OK thanks for the tips.
Yeah I think they are 1x6 planks run diaganolly flat on the floor joists. I suppose I'll have to install this subfloor over these planks?
Old 10-27-2013, 03:40 PM   #10
You would first add ceramic coated decking screws to the planks for extra holding power and to reduce squeaks.
1/2 underlayment rated subfloor will work over the 1 X 6's.
It needs to be nailed or stapled every 4" on the edges and from 6 to 8" in the field.
I use a pneumatic narrow crown staple gun but you can use ring shanked underlayment nails.
crayola110 (11-06-2013)
Commercial vinyl tiles over Advantech subfloor Arky217 Flooring 5 11-27-2012 11:44 PM
Laminant vs vinyl plank flooring gin and ger Flooring 2 01-27-2012 12:31 PM
Another Knucklehead Considers Laying Tile Over Vinyl Flooring tacklingherlist Flooring 14 08-27-2011 12:13 AM
Best Vinyl Plank flooring? mommiemara Flooring 9 07-28-2011 05:15 PM
Installing vinyl plank flooring stevensmr61 Flooring 2 01-23-2011 12:57 PM
