Luxury Vinyl Flooring Installation - Flooring - DIY Chatroom Home Improvement Forum
Old 03-06-2011, 06:50 PM   #1
Luxury Vinyl Flooring installation
I am replacing my Konecto flooring (2nd floor condo) on concrete after one year because of major lifting at seams. Will Armstrong Luxe glued seams stick together when installed on concrete subflooring? Do I need to have installer GLUE entire floor to concrete? Do I need to seal the concrete before applying the floor? I do not want to have the new flooring fail again because of improper installation or an inferior product.
kleinline44 is offline   Reply With Quote
Old 03-06-2011, 10:23 PM   #2
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
Luxe uses a different glue system that isn't suppose to have the issues Konecto had. Personally, I'd do a full spread installation with a different product. Most of these tiles can be installed with pressure sensitive adhesive so they come up fairly easy in the future.
poppameth is offline   Reply With Quote
Tags
armstrong luxe , installation on concrete , seal concrete
using vinyl flooring for tub walls? squarepeg Flooring 15 09-19-2012 10:01 AM
using vinyl flooring for tub walls? squarepeg Remodeling 4 04-27-2011 07:13 PM
Vinyl sheet-cut too short for bathroom flooring tennisdoc1 Flooring 2 04-06-2010 08:30 PM
Old flooring / installing new vinyl tile gwelton Flooring 2 06-24-2009 04:10 AM
Ripping up Vinyl Flooring harmony Flooring 5 02-26-2008 05:50 PM
