Luan Plywood Underlayment - Flooring - DIY Chatroom Home Improvement Forum
Old 05-22-2012, 09:01 AM   #1
Ole Wood Worker
BigJim's Avatar
Rewards Points: 186
I have seen many times here that 1/4" Luan plywood isn't good for underlayment. Some of the men where we go to church are redoing the floor in the kitchen of the preacher's house, it has stick down tile on 1/4' plywood, over old flooring, over particle board, then plywood decking for the subfloor. When I was building I would leave the flooring to the flooring pros so I really don't know which way to go here. The men want to remove the stick down, the 1/4 inch plywood then put 1/4 luan plywood back down then tile or sheet vinyl.
I suggested they use a 1/4 inch sanded plywood instead of Luan, is this correct?
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
oh'mike (05-23-2012)
Old 05-22-2012, 01:02 PM   #2
luan used to be what everyone used under sheet vinyl or 12" selfstick. luan or particleboard has no place under ceramic tile. if they decide on ceramic tile then the particleboard should be removed and replaced with 5/8 or 3/4 plywood, then 1/4 cementboard over that applied following manufacturers guidlines.
Old 05-22-2012, 02:09 PM   #3
Rewards Points: 528
I prefer the 2/8" sanded plywood myself.
No luan please.
framer52 is offline   Reply With Quote
Old 05-22-2012, 05:04 PM   #4
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 42
Luan has voids in the plys and can collapse. Use only underlayment grade plywood for vinyl or vinyl tile.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
The Following User Says Thank You to rusty baker For This Useful Post:
BigJim (05-22-2012)
Old 05-22-2012, 05:37 PM   #5
Rewards Points: 744
No luan please.
2/8" instead of 1/4" ?
Seattle2k is offline   Reply With Quote
Old 05-22-2012, 09:13 PM   #6
Pro
JetSwet's Avatar
Rewards Points: 502
Maybe meant 3/8"?
Luan was big back in the day people still use the stuff now.
JetSwet is offline   Reply With Quote
Old 05-22-2012, 10:05 PM   #7
Rewards Points: 42
Originally Posted by JetSwet View Post
Maybe meant 3/8"?
It's even poorer quality now than it was 20 years ago. They started using luan because so many people screwed up masonite. Masonite was made to be used rough side up and many people installed it smooth side up. Adhesive wouldn't stick to the smooth side.
Old 05-22-2012, 10:18 PM   #8
Rewards Points: 13,270
Luan can also cause staining and glue reliece.
Ever seen a light colored vinyl floor that always looks dirty?
If you have to prove it to some old timers at the church go on the web site of the company that made the flooring before they lay it.
Also make sure they attach it every 4" on the edges, and 6 to 8" in the field.
I use a narrow crown pneumatic staple gun set in automatic to lay it. You can do a whole sheet in less then 2 min. and not have to go back and fill every nail hole. You still have to fill all the seams.
Old 05-22-2012, 10:31 PM   #9
Ole Wood Worker
BigJim's Avatar
Rewards Points: 186
Thanks fellows, I really do appreciate your help. I just had another thought since this floor has particle board over plywood, will the 1 1/4 inch narrow crown staples hold or will I need a longer staple to go further into the plywood subfloor?
Jim
Old 05-22-2012, 11:10 PM   #10
Pro
JetSwet's Avatar
Rewards Points: 502
Well the fact that you can cut it with a razor blade knife is good enough for me not to use it.
Old 03-05-2013, 05:21 PM   #11
Flooting hardwood floors
I'm installing flooting hardwood in my house.The sub floor has a little give in them is this something that will mess up my new floors.
Pantherfan190 is offline   Reply With Quote
Old 03-05-2013, 05:31 PM   #12
DIY staff
Rewards Points: 7,174
Define 'a little'----you may be just fine---but we need a little more info---what is the subfloor made of and how much does it flex?
Could you start a new thread in 'flooring'? many members won't read through an old thread like this one----go to 'flooring' click on 'new thread'---Mike------
Old 03-05-2013, 05:41 PM   #13
Pro
JetSwet's Avatar
Rewards Points: 502
Its better to start new thread.
How to do plywood underlayment for sheet vinyl ken24 Flooring 23 10-19-2011 04:01 PM
Installation options for plywood underlayment? ScooberJake Flooring 0 09-03-2011 12:00 PM
Luan plywood staples under tile? former33t Flooring 3 10-15-2009 02:34 PM
How to install 3/8 underlayment plywood? dangdang Flooring 8 09-26-2009 05:21 PM
Sheet Vinyl....plywood underlayment or luan? AllGoNoShow Flooring 3 05-28-2008 06:57 PM
