Luan Plywood Underlayment
I have seen many times here that 1/4" Luan plywood isn't good for underlayment. Some of the men where we go to church are redoing the floor in the kitchen of the preacher's house, it has stick down tile on 1/4' plywood, over old flooring, over particle board, then plywood decking for the subfloor. When I was building I would leave the flooring to the flooring pros so I really don't know which way to go here. The men want to remove the stick down, the 1/4 inch plywood then put 1/4 luan plywood back down then tile or sheet vinyl.
I suggested they use a 1/4 inch sanded plywood instead of Luan, is this correct? |
luan used to be what everyone used under sheet vinyl or 12" selfstick. luan or particleboard has no place under ceramic tile. if they decide on ceramic tile then the particleboard should be removed and replaced with 5/8 or 3/4 plywood, then 1/4 cementboard over that applied following manufacturers guidlines.
I prefer the 2/8" sanded plywood myself.
No luan please. |
Luan has voids in the plys and can collapse. Use only underlayment grade plywood for vinyl or vinyl tile.
Luan was big back in the day people still use the stuff now. |
Luan can also cause staining and glue reliece.
Ever seen a light colored vinyl floor that always looks dirty? If you have to prove it to some old timers at the church go on the web site of the company that made the flooring before they lay it. Also make sure they attach it every 4" on the edges, and 6 to 8" in the field. I use a narrow crown pneumatic staple gun set in automatic to lay it. You can do a whole sheet in less then 2 min. and not have to go back and fill every nail hole. You still have to fill all the seams. |
Thanks fellows, I really do appreciate your help. I just had another thought since this floor has particle board over plywood, will the 1 1/4 inch narrow crown staples hold or will I need a longer staple to go further into the plywood subfloor?
Well the fact that you can cut it with a razor blade knife is good enough for me not to use it.
Flooting hardwood floors
I'm installing flooting hardwood in my house.The sub floor has a little give in them is this something that will mess up my new floors.
Define 'a little'----you may be just fine---but we need a little more info---what is the subfloor made of and how much does it flex?
Could you start a new thread in 'flooring'? many members won't read through an old thread like this one----go to 'flooring' click on 'new thread'---Mike------ |
| All times are GMT -4. The time now is 02:35 PM. |
