Luan Plywood Staples Under Tile? - Flooring - DIY Chatroom Home Improvement Forum
Old 10-13-2009, 08:34 PM   #1
Luan plywood staples under tile?
My tiling project continues...
I've removed all my vinyl flloor and luan plywood, but still have these staples (look like crown staples, about 3/4" long) every six inches or so in my subfloor. I started pulled them out and it is taking as long as it did to remove the plywood and flooring itself. Any thoughts on whether I'd be okay to just countersink these into the 3/4" T&G subfloor before adding my 1/2" plywood underlayment (followed of course by hardibacker)?
I can see the obvious disadvantage of this plan being the screws for the underlayment hitting the staples, but any thoughts? Anyone done this? It would seem that a pro would either have an ingenious way to get these out or would just pound them in. I can't see someone working as slowly as I did this evening actually making any money on a job.
In case anyone is wondering, the staples were used to apply the luan plywood. When I started pulling on the luan, most of staples pulled right through the top of the wood rather than coming out with it. I can see why this stuff has to come out before putting down tile.
former33t is offline   Reply With Quote
Old 10-13-2009, 08:43 PM   #2
Residential Contractor
I am curious to what the flooring guys on this forum say about this too.
As a remodeler, I have had 2 different floor guys tell me the exact opposite thing. My current one says bang them in, and my previous one said pull them all out. (Of course neither one actually had to do the work!)
rselectric1 is offline   Reply With Quote
Old 10-13-2009, 11:31 PM   #3
Tileguy
JazMan's Avatar
Rewards Points: 422
It's a waste of time to pull them out. Pound them in! Remove only the ones that are bent.
BTW, it takes more time to pound them in then it did to remove the vinyl and luaun too. Don't forget to re-nail or screw the subfloor before going to step #2.
Jaz
Old 10-15-2009, 01:34 PM   #4
Get out of the box!
Rewards Points: 260
I concur with Jaz
Schluters Kerdi Shower System, Ditra. Loxcreens ProVa Mat Shower Systems
Konecto Luxury Vinyl Plank,Armstrong and Hardwood flooring.
https://IndianaFloorsLLC.com/default.aspx
26yrsinflooring is offline   Reply With Quote
Tile over plywood? Thurman Flooring 3 07-12-2009 09:05 AM
Removing tile from plywood underlayment Martinglmt Flooring 3 12-13-2008 07:06 PM
Tile Plywood Sub-Floor Help woodlab Flooring 1 10-21-2008 10:58 PM
Backer board vs. plywood for tile underlayment allpraisebob Flooring 4 01-07-2007 07:44 PM
Vinyl tile over luan? irishghandi Flooring 1 03-08-2006 02:46 PM
