Lowes Surface Source Vinyl Plank = Excellent! - Flooring - DIY Chatroom Home Improvement Forum
Old 06-04-2012, 05:30 PM   #1
Rewards Points: 12
Lowes Surface Source Vinyl Plank = excellent!
never mind
tinan is offline   Reply With Quote
Old 06-04-2012, 05:34 PM   #2
kwikfishron's Avatar
Rewards Points: 576
Please report back in 5 years (or even one) with an update.
kwikfishron is offline   Reply With Quote
Old 06-04-2012, 05:41 PM   #3
Rewards Points: 12
n/m
Obviously not welcome here
Old 06-04-2012, 06:17 PM   #4
Rewards Points: 576
Originally Posted by tinan View Post
n/m
I apologize, you're absolutely welcome here.
I just have doubts about the longevity of .80 sq.ft. flooring.
Your install looks great... I'll shut up now.
Old 06-04-2012, 07:09 PM   #5
Rewards Points: 12
Obviously longevity is not the first priority for everyone. As I said in the threads where I asked questions about vinyl plank only to have people try to "sell" me on engineered wood, which was out of the question due to cost. We just need something to make the place liveable for the next few years. You may have noticed what we were starting from, and that this is not a luxury custom home. We may not even live here in 5 years. This flooring is entirely appropriate for our gOals.
Also we had Shaw engineered wood in a previous condo it scratched and dented very easily, and a stray ice cube that escaped and melted in a corner caused damage it could not tolerate any moisture at all. So that's what you get for $8 per sq ft.
Old 06-05-2012, 07:42 AM   #6
Rewards Points: 236
don't think that way. he was just being blunt, but not rude.
i know where you are coming form. i used to hate laminate. thinking it was ugly and not durable. but these days, they are making both a lot better. when i do my floors, laminate is what i am going to look into and probably use.
Fix'n it is offline   Reply With Quote
Old 08-04-2012, 06:28 PM   #7
I would love to see the original post about the Lowes Surface Source planks. I have looked at them but don't know anyone who has tried it.
Edited to correct: I have looked at something called Project Source vinyl planks at Lowes. I don't see anything called Surface Source. Is it the same thing?
Rainyday is offline   Reply With Quote
Old 08-04-2012, 07:46 PM   #8
Rewards Points: 12
THe product is here:
http://www.lowes.com/ProductDisplay?...llow&cId=PDIO1
Surface Source 6"W x 36"L Classic Chestnut Floating Vinyl Plank
Here are the photos of my install, I did it all myself - first flooring job ever. I removed the carpet, pulled up tack strips on the wood subfloor upstairs and scraped off the glue residue on the concrete slab downstairs. That was the hardest part. Sealed the concrete with DriLock, then put down the floor. It was super easy to install, just keep lots of sharp exacto knife blades on hand - a sharp blade and a metal square and measuring tape are all you need. Oh, and gloves - after a while the edges of the cut planks will rough up your hands.
https://picasaweb.google.com/tina.no...eat=directlink
Rainyday, I don't know if they have a different name but these are definitely called Surface Source and are a Lowes brand. I tested samples of this along with Home Depot Allure and Armstrong etc, this one was the cheapest and yet the hardest to scratch. We have been living on it about 2 months now and there is absolutely no damage or problems. I did install the floor when it was 75-80 degrees out and I recommend installing it in warm weather and getting the seams very tight. The floor may expand and contract a bit due to temperature and I think people have had buckling if they fit it in too tight in colder weather.
I liked the fact that these planks have a tape-like adhesive system, rather than the overlapping vinyl layers like Allure. I am sure it is much cheaper to use this tape system but I think it is also less likely to cause buckling or curling up. If any corners come up, I plan to simply glue them down but so far so good.
I did the 1500 sq ft townhouse for less than $1000.
Old 08-04-2012, 08:04 PM   #9
Wow that looks really good. Thanks for the link. I am seriously considering this now.
Old 08-04-2012, 08:09 PM   #10
Rewards Points: 12
I have had a lot of people actually think it is wood. It looks better than most laminates, and it doesn't make any snap crackle noises.
Old 08-07-2012, 09:05 AM   #11
looks good ... i am in the process of buying a house and going to have remodel the basement to be my home office, and that was the exact floor i was looking at. Thanks for posting pics, great to see them install and get someone feedback on them.
bigmike203 is offline   Reply With Quote
Old 08-07-2012, 09:49 PM   #12
Rewards Points: 12
I would be a bit cautious in using a floating vinyl floor in a basement though - be sure to have it moisture tested at the wettest time of year first. I have read stories of mold growing underneath, because moisture can be trapped. If the concrete is dry, I would still seal it first with something like Dry-lok like I did, to make sure no moisture weeps up through the concrete. This is the stuff I used, if it was a basement I'd probably do multiple coats:
http://www.ugl.com/drylokMasonry/mas...ofer/latex.php
Old 03-06-2013, 08:22 PM   #13
Thumbs down
surface source
never mind
Its the worst flooring ever.. read consumer reports on this junk flooring BEWARE=BEWARE do not put your installer through the hassle over this cheap 89 cents pr sq ft garbage.. Not the installers fault when it buckles up on you and you trip on it in the middle of the night.. PLEASE DONT CHOOSE THIS FLOORING.
2244mac is offline   Reply With Quote
Old 03-06-2013, 09:58 PM   #14
Rewards Points: 12
Well, it's holding up great in my house, and I installed it myself as my first flooring job. Many people have remarked that it looks pro. I installed 1500 sq ft of it in our townhouse with 4 (long) days of work with no previous flooring experience at all. So if you "don't want to put your installer through that" I don't know if your installer is worth his or her pay.
Hey, I realize half of you sell expensive flooring for a living, so keep on doing that, but I am happy with my less than $1/sq ft floor with no extra costs for installation, tools or underlayment.
We've had it in for almost a year now, through hot summer and through winter and no warping, peeling lifting or any problems whatsoever. I simply followed directions and made careful calculations to install it properly and have a perfect floor as a result.
It's very durable, haven't made a scratch on it moving furniture around, cats running on it with untrimmed claws, everything sweeps and mops right up to brand new with my steam mop. I painted the kitchen and got some flecks on the floor, was able to scratch them off with a scrubby sponge and no marks left behind.
Care to name any reasons that the review you read states it is so bad? Lots of hearsay going around, but I seem to be the only person here who has actually installed and lived on this product.
It is excellent, and unfortunately no longer available, I may have gotten it on clearance. In any case I don't think you possibly beat it for value for money. I would not hesitate to use a similar products again. A quick no special-tools install (and no noise and dust either - nice for a townhouse to not make your neighbors hate you before moving in) and this durability and price? You really can't beat it.
I'll put back up my photos for anyone who actually cares for a personal experience with the product instead of just hearsay. If you choose to insult my home and my hard work on it, please think twice before being an ass.
During install upstairs over elderly plywood subfloor all I did was remove protruding nails. I did not remove baseboards because they were already "carpet height" and had adequate clearance to slide under and allow for expansion, though I installed in 80 degree weather so I fit the seams as tight as I could knowing that it was already max expanded. Some people may prefer some quarter round but I don't like the look myself and don't mind the 1/8" gap between planks and baseboard. If you put in quarter round fix it to the baseboard and ensure some expansion space is left, no attaching it to the floor through the planks.
I undercut the door jams to slide under with no pressure on the flooring. With planning and calculations I was able to get a continuous install throughout all rooms with no ugly transitions.
Downstairs it went in over concrete slab (ground level) which I sealed with Dry-lok first as a precaution.
Nearly done
powder room, new baseboards not yet caulked and finished
NOW...
The Following User Says Thank You to tinan For This Useful Post:
operagost (04-08-2013)
Old 03-07-2013, 05:13 AM   #15
Rewards Points: 125
I understand and appreciate the input here from those that strictly recommend top end products, a contractor gets held accountable to a way higher standard than any homeowner would hold himself to, but for a lot of us, it's a case of "do it cheap or do without". I just did a laminate floor, yes I know it was "cheap" stuff but it beats the hell out of the mess that I had before, and it buys me some time. I can consider something longterm and pricier later at my leisure, not just live with the crappy floor we inherited when we bought the house, and when I tear this one up and toss it I am only out $150, I won't be worried about whether or not I got my moneysworth.
ThatDaveGuy is offline   Reply With Quote
Surface Source / Congoleum Endurance Plank GMD Flooring 0 01-02-2011 09:16 PM
vinyl plank flooring? annie68164 Flooring 1 08-18-2008 12:10 AM
vinyl sheet or tile (or allure) over old vinyl? thomase Flooring 8 06-30-2008 05:15 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
