Low Spot In Subfloor - Flooring - DIY Chatroom Home Improvement Forum
Old 03-02-2013, 10:12 PM   #1
Low Spot in Subfloor
I bought a house (a bi-level) about 4 years ago and immediately tore out a nasty, dog-hair infested carpet and installed a laminate floor. Over the years from walking on the floor, we have found that their is a low spot in the sub-floor as soon as you get to the steps. I have determined this because the laminate boards are separating on the side where the boards slide together (short side). I have already tried sliding the boards back together and it worked for a short time, but then the boards separated again.
I am looking for ways to fix the issue. I am aware that I may have to remove the flooring and then use a self-leveling product, but I was hoping there would be another solution. I am open to all ideas.
pbcleff is offline   Reply With Quote
Old 03-02-2013, 11:30 PM   #2
Rewards Points: 13,300
Have you looked under the floor in the crawl space or basement to see why it's sagging?
Old 03-03-2013, 01:11 PM   #3
joecaption,
I do not have access to look underneath the floor at the structure because the floor below has a finished ceiling. I do know that there is a solid I-beam under the location where there is a low spot in the sub-floor. In my opinion, I think the reason why a low-spot has formed is because it is at the top of the steps so it is heavy traffic area and it is possibly between two beams.
Old 03-03-2013, 01:17 PM   #4
Or someone cheaped out and only used a 1/2 subfloor.
Old 03-03-2013, 01:19 PM   #5
Very well could be possible. The house was built in 1979, so it has some age to it. Any ideas/suggestions on how to fix it?
Subfloor and P-trap for basement bathroom svaic00 Plumbing 9 10-11-2012 01:51 PM
small low spot in subfloor mwmonty Flooring 6 01-02-2012 01:24 PM
Fixing low spot on subfloor JoseB Flooring 2 11-22-2009 06:00 PM
Need guidance on subfloor problems in new home. wb1026 Flooring 9 10-06-2009 07:29 AM
Subfloor with High Spot anthony9887 Flooring 1 08-12-2008 09:51 PM
