Loose Underfloor - Flooring - DIY Chatroom Home Improvement Forum
Old 04-29-2008, 07:17 AM   #1
loose underfloor
Have plywood under carpet that needs fastening more securely in places. Most stud finders not capable of locating studs through layer of carpeting. Any way to find studs and, if so, best way to drive fastener through to the floor.
mitch33 is offline   Reply With Quote
Old 04-29-2008, 11:01 AM   #2
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,362
I've seen a gadget on the TV show This Old House where you can tighten down the loose spot in the subfloor using a special screw. Once it's just below the surface of the subfloor, you break off the head of the screw. Finding the joist was a hunt and peck though.
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Abloy Front Door Lock is loose - how to open to tighten Wayne_in_Canada Windows and Doors 4 09-23-2012 07:48 PM
Slate Floor Electric Underfloor Heating Lottie Flooring 6 03-19-2011 01:50 PM
help, loose door hinges screws clyde Carpentry 13 12-19-2007 01:31 PM
Water piple attached to the wall loose 707782 Building & Construction 6 10-20-2007 12:10 AM
Is there a Disadvantage to Underfloor Heating? herbolaryo Flooring 1 08-24-2007 02:18 PM
