Loose Tile On Lightweight Concrete Subfloor. Help! - Flooring - DIY Chatroom Home Improvement Forum
Old 08-16-2011, 12:42 PM   #1
Loose tile on lightweight concrete subfloor. Help!
Hi Folks,
My friend (a pro tiler) recently installed porcelain tiles in my 9x11 galley kitchen. His father who owns the business mentioned that the lightweight concrete (possibly gypcrete?) subfloor could pose a problem. My friend decided since the original laminate was installed on the subfloor, the tiles could just go over it. Since he was the pro, I thought nothing of trusting him with his opinion.
Flash forward a few weeks later, and grout has been cracking and chipping. Now two tiles are noticeably loose when walked on. I have done a bunch of research, but am not really sure how to proceed. What makes it especially hard is the installer is my friend. Any thoughts on how to proceed with fixing this mess?
bassgod1 is offline   Reply With Quote
Old 08-16-2011, 01:32 PM   #2
the Musigician
DangerMouse's Avatar
Hi and welcome to the forum.
If he's truly your friend, ask him to come back and look.
Perhaps his estimate on the strength was off?
DM
Old 08-16-2011, 01:32 PM   #3
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 124
Originally Posted by bassgod1 View Post
Hi Folks,
I assume you mean linoleum. At this point, you will probably have to remove it all including the linoleum or vinyl. It probably wasn't adhered to the floor in some places. How did your friend install the tile?
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 08-16-2011, 01:48 PM   #4
Thanks so much for the welcome, DangerMouse.
Sorry Rusty! Totally meant linoleum. There was a cheap peel 'n stick tile above the original linoleum. He took that out and determined removing the linoleum from the LWC subfloor could cause a lot of damage. He used a mapei thinset mortar and placed the porcelain tiles (13x13) straight onto the linoleum. His thinking was the linoleum flooring would prevent shifting. It was also his thinking that using a ditra underlayment wouldn't really help in this scenario. Would removing the installed tile irreparably damage the subfloor?
Tile on concrete floor with radiant heat shutterjen Flooring 4 12-09-2009 11:22 AM
concrete paint removal before tile installation SR996 Flooring 1 03-21-2009 07:31 PM
Old Tile on Concrete floor bmenton Flooring 1 01-27-2009 06:53 PM
tile over exterior concrete? BlueMoonBean Flooring 6 11-18-2008 01:55 PM
Concrete basement slab + Radiant + Tile MageMinds Flooring 4 08-21-2007 12:52 PM
