Old 01-10-2011, 11:59 AM   #1
loose lay vinyl???
I just installed some loose lay vinyl in my kitchen - when moving the refrigerator back in, in one corner slid across the floor. Now there is a wrinkle/crease on our 1 day old vinyl.....is there any way to repair this? If I roll it back and glue it down, do you think that will help?
cakomar is offline   Reply With Quote
Old 01-10-2011, 02:11 PM   #2
loose lay vinyl???
Yes . Never been a fan of loose lay .
When you get the fridge back to the hole it goes in , spray a little Windex behind the wheels .
She'll slide in like it was on ice . wipe up the Windex.
Floor Doc is offline   Reply With Quote
Old 01-10-2011, 02:27 PM   #3
Experienced
Jackofall1's Avatar
loose lay vinyl???
Did you ever see "My Big Fat Greek Wedding", windex works for everything........, seriously though good tip.
Old 01-10-2011, 04:04 PM   #4
loose lay vinyl???
No Jack, Now you have my curiosity peaked .
Old 01-10-2011, 04:49 PM   #5
Tileguy
JazMan's Avatar
loose lay vinyl???
Hey Doc,
The Windex trick has piqued my curiosity too.
And yes, loose lay sucks, but they're very popular since they require less substrate prep making the installation cheaper.
Jaz
Tile 4 You LLC Troy, MI
KERDI Shower Specialist ... DITRA Installs ... Product-Method suitability consultation. I have NEVER made a mistake, I thought I did once...........but I was wrong! - PRODUCTS ADVERTISED WITHIN MY POST ARE NOT ENDORSED BY ME!
Old 01-10-2011, 06:14 PM   #6
loose lay vinyl???
It works Jaz . been using it for years , even on those double wides .
vinyl sheet or tile (or allure) over old vinyl? thomase Flooring 8 06-30-2008 06:15 PM
vinyl siding piece comes loose dderolph Building & Construction 3 11-03-2007 05:56 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
