Loose Carpet On Stairs - Flooring - DIY Chatroom Home Improvement Forum
Old 05-20-2008, 06:12 AM   #1
Rewards Points: 150
loose carpet on stairs
I had a problem with one of my treads, cut the carpet, fixed the tread and now I cant get the carpet tight to the tack board. What tool to use and how to fix it would be most helpful. Thanks.
econdave is offline   Reply With Quote
Old 05-28-2008, 06:25 AM   #2
Rewards Points: 150
no one knows this
I cant believe all the readers and no one can guide me how to fix this problem?
Old 06-15-2008, 10:29 AM   #3
probably too late now but....
Secure the carpet at the bottom of the riser to the tackless strip. You may need to staple it.
Stretch the carpet by hand to contour the stair to look like the other stairs. If it is french cap where the carpet rolls neatly around the cap you will have to force it into the top of the riser into the tread corner and staple. If it is waterfall just stretch by hand until the carpet is on the tackless on the tread, starting in the middle and working out.
Rent or borrow a carpet kicker and kick it onto the tackless. It is a little awkward, I know. Make sure the teeth of the kicker are set to the height of the carpet and backing, hold the handle down firmly so that the kicker doesn't skid over the carpet ruining the face and injuring your groin.
Again start in the middle and and work out.
HomeDepot23 is offline   Reply With Quote
Changing from carpet stairs to wood stairs DIY_user Remodeling 16 07-29-2010 08:16 PM
Carpet on stairs loose econdave General DIY Discussions 4 04-27-2008 07:23 PM
Gaps at baseboards after carpet install cometbus Flooring 9 10-01-2007 08:48 PM
