Looking For Soft Flooring To Put In Bathroom For Elderly Lady - Flooring - DIY Chatroom Home Improvement Forum
Old 08-03-2007, 02:16 PM   #1
Looking for soft flooring to put in bathroom for elderly lady
My great grandmother has falling in bathroom. Is there any soft padding I can use as a floor for her.
pyrowolf is offline   Reply With Quote
Old 08-03-2007, 05:44 PM   #2
Home Improvement Guy
ron schenker's Avatar
Cork would be the least painful flooring, however if she's falling in the bathroom I would recommend installing some grab bars to help her stay up! If you don't want to replace the flooring that's there now you could lay down some of that rubber floor pad that is used in gyms.
ron schenker is offline   Reply With Quote
Old 04-26-2008, 12:02 AM   #3
isn't rubber flooring too slippery for a bathroom floor. You also have to think about it getting wet also. The only solution is putting grab bars all throughout the bathrrom. on the doorways and such
lleckie88 is offline   Reply With Quote
Old 04-26-2008, 08:28 AM   #4
Rewards Points: 1,274
How about some shaggybathroom carpet? But even if you solve the hard floor issue, there's still the hard toilet, tub, and vanity issue.
LawnGuyLandSparky is offline   Reply With Quote
Old 04-26-2008, 10:08 AM   #5
Knucklez's Avatar
Rewards Points: 932
cork is a good idea. you can find it on ebay too.
if you live near toronto ontario canada, a good source is http://www.dufferintile.com/
Knucklez
Knucklez is offline   Reply With Quote
Old 04-26-2008, 10:41 AM   #6
Guest
Guest
Posts: n/a
Cushioned back vinyl is another option. However any of these options (short of the carpet) won't give enough cushion to make any difference in this case.
Old 04-26-2008, 11:36 AM   #7
J Calvin Construction
jcalvin's Avatar
Rewards Points: 150
I am not sure if there is any available flooring that would make a difference. If you get is too soft she possibly could have a hard time walking on it, kinda like a mattress. My papaw had parkinsins and vinyl/hardwood was the best for him. He could use his walker and it wouldn't catch on the flooing and it is a firm floor to walk on.
Cal
You hired WHO?
jcalvin is offline   Reply With Quote
Old 04-28-2008, 03:03 PM   #8
ayeshaa's Avatar
Rubber
Soft, non-slip, easy-to-clean, waterproof and very hardwearing, rubber flooring is ideal for bathrooms. Choose from sheet or tiles in smooth or studded finishes, in a huge range of colours.
Vinyl
Hygienic and waterproof, vinyl comes in sheets or tiles. Cushioned vinyl is softer and warmer, while harder types come in a variety of finishes. It must be laid on an absolutely flat surface.
ayeshaa is offline   Reply With Quote
Old 04-28-2008, 03:25 PM   #9
Rewards Points: 1,910
I wonder if the right answer is a soft floor. She can still hit her head on the vanity, stool and tub which is more of a concern than the floor - and a soft floor might promote tripping. Nonslip-yes, soft I question.
I would focus on the means to prevent the fall like the grab bars.
bathroom flooring carebear560 Flooring 9 07-24-2012 07:12 PM
Bathroom Flooring bbrown92y Flooring 10 05-27-2008 10:49 AM
Bathroom flooring (tile?) Nhrafan Flooring 30 06-11-2007 11:44 AM
Chlorine Resistant Flooring for Bathroom herbolaryo Flooring 7 05-22-2007 09:05 PM
Laminate Flooring - Is It Installed Under Bathroom Cabinets? BDPNA Plumbing 92 02-07-2007 12:02 PM
