Looking For Dricore Leveling Alternative - Flooring - DIY Chatroom Home Improvement Forum
Old 03-29-2010, 11:06 AM   #1
Looking for Dricore leveling alternative
Hi all
I'm installing Dricore subfloor in my 800 sq.f. basement. So far everything is good. 60% done. My floor is relatively leveled except 1 single place where floor drain is located.
The area around floor drain (about 2 feet radius) is slopping down about 1.5 inch. So I have to use a lot of Dricore shims. At some point almost whole package to keep floor leveled.
I stopped the installation as it seems wrong to put that amount of leveling shims. They are still bouncing. + Cost of shims kills the whole deal on floor.
So I'm looking for some alternative to these expensive shims. Some king of plastic board which I can cut and put like support under Dricore boards.
Is there anyone who had similar problem ans solved it?
Thanks everybody, and looking forward for answers.
vluzhko is offline   Reply With Quote
Old 01-03-2012, 10:21 AM   #2
I have used strips of asphalt shingles to level basements subfloors. They are waterproof and are easy to stack and layer.
rhys is offline   Reply With Quote
Old 01-03-2012, 06:10 PM   #3
Good idea. I did not coume out to this one and instead used concrete to rise drain slope. It still correct as I tried bucket of water to test the result. I had to use 3 bags of concrete.
Any ways I have finished everything long ago. But your advise with shingles is very helpfull as I see now that I would go with it.
Hopefully this helps someone in future.
Leveling a converted garage floor Monpz Flooring 1 02-24-2010 11:42 AM
floor leveling compound geraldS Flooring 4 03-01-2009 09:20 AM
Portland based self leveling underlayment under travertine floors Keith Carlson Ceramic Flooring 7 01-25-2009 04:58 PM
clawfoot tub leveling extensions domijita General DIY Discussions 1 10-17-2007 09:29 PM
Leveling concrete floor - problem McCool Flooring 3 12-05-2006 10:31 PM
