Lock N Fold Floor Is Noisy - Flooring - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-14-2011, 04:42 PM   #16
i have installed many brands of floating floor, we cured the cracking and creaking on one installation by (soft) brooming talcum powder over the floor and allowing it to work into the joints before removing the excess that job was over 2 years ago and the customer has had no more issues. providing your sub floor was within the tollerances for that brand of flooring this could be a cheap fix
kiwi7 is offline   Reply With Quote
Old 10-14-2011, 06:37 PM   #17
Hi,
Thanks, but that was ruled out, mainly because we were told that the talcum could cake up, and in the black "lines" of the floor, it would look awful. It would also void any warranty, because they could say it wasn't within the proper care, like now, when it says in the care of the floor, you must use that Bruce floor cleaner, so cleaner and water...every little thing will get ya', so you have to be very very careful.
aquilter is offline   Reply With Quote
Old 05-01-2012, 03:43 PM   #18
I was told by a contractor that if you apply patch or self leveling compound to a surface like vinyl you will have the problem you are describing. The patch compound will not adhere and will start to crack where it is feathered. He suggested that the vinyl be coated with a special primer and then use the self leveling or patch compound.
robert1948a is offline   Reply With Quote
Old 07-01-2013, 05:32 PM   #19
I am having the same popping/cracking sound with my Armstrong Bruce Park Avenue floor. So far I feel that I am getting the runaround by Home Depot and Armstrong. Has anyone had this issue resolved? Is there a class action suit on this issue?
Greyharley is offline   Reply With Quote
Old 07-01-2013, 08:43 PM   #20
Rewards Points: 66
its a level issue have the same problem in a floor I did for myself.
digitalplumber is just a name for use here, I am not a plumber!
digitalplumber is online now   Reply With Quote
Bruce Lock & Fold engineered hardwood? zel Flooring 102 01-30-2013 11:31 AM
Cabin grade vs 1st quality Bruce Lock N Fold Treasures Flooring 4 09-12-2009 10:03 PM
Dodge Caravan 2005 driver door lock Wildie Automotive Repairs 11 11-20-2008 03:18 PM
garage door lock jack_j General DIY Discussions 1 12-27-2006 06:40 PM
noisy tap (really noisy!!) - help please Nikki Plumbing 2 04-23-2006 08:56 AM
