Load Bearing - Laminate Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 02-27-2012, 03:05 PM   #1
I have a sub floor, and then natural wood floors. The planks are pine about 8 inch wide. The floors are ruined from animals and just about anything that has touched the floor due to soft floor. I want to put a laminate over the floor. I do not want to remove the floor. I was told by the supplier that we could have load bearing issues with three layers of floor. The basically would not warranty the floor if I purchased. We have a crawl space under the home and concrete block bases under the home. I have never heard of load bearing issues. Has any one had this type of issue?
srzink is offline   Reply With Quote
Old 02-27-2012, 03:18 PM   #2
DIY staff
Rewards Points: 7,174
Sounds like nonsense to me---It should not be an issue---
The warranty on most brands is not worth the paper that it's printed on---so you are on your own any way---Mike---
Ditra under Laminate Floor? HECO Flooring 3 04-30-2012 08:00 AM
Wine rack as load bearing wall? lisa7932 Building & Construction 5 02-27-2012 12:53 AM
Help identifying load bearing wall and flooring help! (video) mikedavid00 Building & Construction 6 04-03-2010 10:57 PM
Basement Flooring: Laminate material atm Flooring 1 06-30-2009 10:34 AM
Counter top plastic laminate Gerry Kiernan Interior Decorating 4 10-13-2008 10:44 AM
