Little Lumps In Hard Wood With Polyurethane - Flooring - DIY Chatroom Home Improvement Forum
Old 04-07-2012, 06:08 PM   #1
little lumps in hard wood with polyurethane
I did a small amount of red oak flooring myself. Came out good. I sanded it flat. When I did the first coat of polyurethane I felt some grainy things in it. I re-sanded it smooth with 150 grit sand paper, vacuumed it the best I could. It felt really smooth to the touch. I did a second coat and applied it lightly with the lamb wool applicator. Its still drying, but it looks like it will have same tiny lumps in it.
What would I be doing to cause this? Also is there a quick way to buff it smooth without doing another coat of polyurethane because I really don't like the smell.
da_man is offline   Reply With Quote
Old 04-07-2012, 06:54 PM   #2
Stairguy
Millertyme's Avatar
Rewards Points: 508
the first coat usually comes out a little rough. With it being a floor you are going to want to do at least 3 coats of poly. Sanding lightly between is common practice but is not always required. You could have had some dust in the air still kicking around when you applied the second coat. Make sure your brush is clean. It could also be air bubbles in the poly. If it is you can use a thinned coat to help rid them. One you get a few coats on the floor and it is cured completely you can use a rubbing compound to buff the floor. But be careful not to make it too slick...it is a floor.
Millertyme is offline   Reply With Quote
Old 04-07-2012, 06:56 PM   #3
Experienced
Jackofall1's Avatar
You need to use tack rags before you apply the next coat.
I know the smell is wonderful isn't it, but the more coats the longer it lasts, generally 3-4 coats is required.
Mark
Old 04-08-2012, 11:20 AM   #4
May need to strain / filter the poly U .
Chetco is offline   Reply With Quote
Old 04-09-2012, 01:11 PM   #5
The only option is to buff the floor with a 220 grit and then recoat. As the other guy mentioned this will addd more protection.
RhodesHardwood is offline   Reply With Quote
Oak dust and polyurethane as a wood filler onthebrinck Carpentry 7 08-18-2011 06:43 AM
Wood Flooring Sealing and Polyurethane edro Flooring 3 05-10-2011 09:45 PM
Ceramic Tile versus Engineered Hard Wood john curry Flooring 1 02-14-2010 05:18 PM
flooring frankiedog Flooring 7 12-05-2008 01:05 PM
prepping old wood for painting newb questions afabco Painting 19 08-07-2008 11:19 AM
