Linolium Over Basement Slab - Flooring - DIY Chatroom Home Improvement Forum
Old 12-16-2011, 09:41 AM   #1
Rewards Points: 155
linolium over basement slab
I finished carpeting the "living" side of the basement- There is a small area about 10'x8' where the laundry/water heater is (unfinished side)- I wanted to just put some sheet linolium there to provide a little better surface than the concrete floor- is there anything I should put down prior to laying the sheet flooring? (something to prevent mousture maybe?)- I have a dehumidifer that runs all the time down there but I did not want to give mold a chance to grow under anything. Wasn't sure if there is anything to put down to prevent or help prevent any issues
Huskyfan68 is offline   Reply With Quote
Old 12-16-2011, 10:33 AM   #2
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Just put it right on the concrete.
Sent from a Samsung Galaxy S2
titanoman is offline   Reply With Quote
Old 12-16-2011, 11:40 AM   #3
Tileguy
JazMan's Avatar
Rewards Points: 288
If the conditions are proper, it goes right on the slab.
But, why are you running the dehumidifier all the time? You're not supposed to do that. Do you have a moisture problem, mildew musty smell?
Jaz
JazMan is online now   Reply With Quote
Wet basement - don't know where to start konradsa Building & Construction 17 09-20-2011 11:08 AM
Ditra over basement slab? Trustmemalawyer Flooring 1 08-12-2011 06:58 PM
2X4 Framing on sloped basement slab chobio Building & Construction 2 07-02-2011 09:11 AM
bathroom basement subfloor on concrete slab Gus72 Building & Construction 9 01-19-2008 06:57 PM
Concrete basement slab + Radiant + Tile MageMinds Flooring 4 08-21-2007 01:52 PM
