Linoleum Tiles Held On With... Tar? - Flooring - DIY Chatroom Home Improvement Forum
Old 01-08-2013, 04:08 PM   #1
Linoleum tiles held on with... tar?
Hey all, I'm redoing my kitchen floor and planning to put down ceramic tiles.
After some reading it seemed clear that I need to remove the old tiles and put down 1/4" backerboard. The problem is that the old linoleum tiles seem to be held down with tar.
My big tile removing shovel won't slide along at all... at best it takes chunks out of the plywood underfloor. I have peeled off a few tiles with a hammer and chisel, but this process will take a very long time.
Is it possible to but backerboard over linoueum? If so, what kind of adhesive could I use? Or should I slug it out and remove the tiles... and will backerboard + thinset adhere well enough to tarry ply? Thanks RR
Red Robin is offline   Reply With Quote
Old 01-08-2013, 04:13 PM   #2
Rewards Points: 14,300
It's mastic not tar.
Figure out what's under the tiles if it's 1/4 anything that also should go.
How old are these tiles? Some contained asbestos.
Have you checked the floor joist and subflooring to see if tile will even work there? We need the spans, spacing species and width.
Red Robin (01-09-2013)
Old 01-08-2013, 04:24 PM   #3
DIY staff
Rewards Points: 7,174
That black stuff is called 'cutback' and was used from the 1940s into the 1960s when more friendly adhesives became available----
Old 01-08-2013, 04:32 PM   #4
DIY staff
If the old tiles are very secure--you have a couple of options---
Option #1--Cut your 1/4" backer to fit---remove--then trowel down a bed of modified thinset--install the board --add roofing nails or screws and set the tile---
Option B---Install 3/8" or 1/2" BC plywood over the existing subfloor---then your 1/4" tile backe as above---
Either will work---with the old tiles and cutback--often it is best to bury it than to disturb the old material.
More details are needed to get a fancier answer ====
Old 01-08-2013, 06:36 PM   #5
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 182
The cutback adhesive and tiles, both probably contain asbestos.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
rusty baker is online now   Reply With Quote
The Following User Says Thank You to rusty baker For This Useful Post:
Old 01-09-2013, 09:24 AM   #6
Thanks all for the replies. I didn't know that older tiles contained asbestos. This is very worrying. I think my best choice is to simply cover the old tiles as I do not want to mess with asbestos. I figure I will put down a layer of thinset (with a poly mix?) screw on backer, and put the tiles on that. This will make for a thick joint between tiled floor and hardwood, but I don't mind. Cheers RR
Old 01-09-2013, 05:10 PM   #7
DIY staff
The thinset is there only to fill in any voids--1/4 x1/4---or 1/4 x 3/8 will be fine---modified thinset is what I use---
Old 01-10-2013, 03:03 PM   #8
Thanks Mike, I was just coming back to check on that. Just to clarify- I can screw down the backerboard onto the linoleum without thinset underneath, yes? The thinset is just used to fill voids, and I would trowel it on over the backerboards. I hope I have this right. Thanks RR
Old 01-10-2013, 06:43 PM   #9
Rewards Points: 182
No, you must put thinset under the CBU, too.
Red Robin (01-11-2013)
Old 01-10-2013, 07:33 PM   #10
DIY staff
Set the backer board as if it was a big tile----then nail with roofing nails or Rock screws---you want thinset under the backer to fill any voids---
Old 01-11-2013, 10:01 AM   #11
Ah, I see what you mean. Thanks! RR
Tags
backerboard , ceramic , linoleum , tar
Help! Vinyl tiles over linoleum mess Tatka75 Flooring 11 11-03-2012 07:27 PM
How do I lay linoleum tiles on pier and beam floor. This is in my kitchen. sjcoop Flooring 18 09-17-2012 05:50 PM
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 06:10 PM
sticky tiles over linoleum? Bushman Flooring 5 04-30-2010 08:35 AM
Replcing linoleum with 12x12 tiles fburke Flooring 2 10-29-2005 08:03 AM
