Linoleum On OSB Subfloor - Flooring - DIY Chatroom Home Improvement Forum
Old 09-27-2011, 08:38 PM   #1
Rewards Points: 1,062
Question
linoleum on OSB subfloor
i wanna put linoleum on my OSB subfloor in the washer/dryer alcove. was wondering how to do it and if i can just simply glue it to the subfloor.
thanks
Old 09-27-2011, 08:42 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 14
Linoleum or vinyl?
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 09-27-2011, 08:50 PM   #3
Originally Posted by rusty baker View Post
Linoleum or vinyl?
i dunno. it really doesn't matter. i just need something over the OSB subfloor before i put the washer so that it's not a bare floor. the most minimalist solution. what do you recommend?
Old 09-27-2011, 09:05 PM   #4
Rewards Points: 14
Vinyl is easier to handle and cheaper. Just glue it down.
The Following User Says Thank You to rusty baker For This Useful Post:
amakarevic (09-28-2011)
Old 09-27-2011, 09:23 PM   #5
Rewards Points: 150
Fiberglass sheet flooring. Easiest type of vinyl sheet goods to deal with.
OhioHomeDoctor is offline   Reply With Quote
Old 09-27-2011, 10:09 PM   #6
Rewards Points: 14
Like any flooring, it has it's pluses and minuses.
Old 09-27-2011, 10:11 PM   #7
Rewards Points: 150
The only one I'm aware of is more expensive glue.
Old 09-27-2011, 10:22 PM   #8
Rewards Points: 14
Then you haven't installed a lot of it. I have installed hundreds of yards of it. The washer/dryer sitting on it can be a problem.
Tags
linoleum , subfloor
Need guidance on subfloor problems in new home. wb1026 Flooring 9 10-06-2009 07:29 AM
Replacing Subfloor whatispunk Flooring 1 09-01-2009 10:50 PM
Subfloor Help, Please! OmahaGirl Flooring 1 01-26-2009 09:06 AM
What final material should be on the subfloor before linoleum? Alan Flooring 3 07-19-2008 07:57 PM
Subfloor / underlayment question... scheenstra Flooring 7 02-21-2008 08:39 AM
