Linoleum: How-to? - Flooring - DIY Chatroom Home Improvement Forum
Old 04-03-2011, 01:54 PM   #1
Linoleum: How-to?
I want to put some linoleum down in my bathroom. What type of floor surface do I need? Currently it's down to the construction floor. I think I need to add another layer of plywood, and if so, what kind? Does the floor have to be levelled before installation? Any tips or how-to's are much appreciated.
mforeman1 is offline   Reply With Quote
Old 04-03-2011, 02:13 PM   #2
I would install a thin plywood underlayment, level any low spots and the seams with cement patch, sand down the patch and install.
edit - assuming you're talking about some sort of vinyl, not real linoleum.
MCTF is offline   Reply With Quote
Old 04-03-2011, 02:19 PM   #3
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 148
Installing vinyl can be done by a DIYer, but linoleum install is not really a DIY job.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 04-03-2011, 02:29 PM   #4
Yes I agree I forgot to mention that.
Old 04-03-2011, 04:19 PM   #5
Alright, I think I want to install vinyl then - I guess I made a mistake between the two.
It's a bathroom, so the flooring would have to be somewhat water resistant. Is vinyl ok for this? From what I've read, it should be, but apparently vinyl also offers a certain sound-dampening characteristic.
Does vinyl need to be glued down?
Old 04-03-2011, 04:25 PM   #6
Rewards Points: 148
I think it's better to glue vinyl but there are several that don't have to be glued.
20x20 Porcelain Tile over Linoleum on Concrete Slab scbauer Tiling, ceramics, marble 3 08-31-2010 07:11 PM
Old linoleum and new ceramic tile tmramrod91 Flooring 0 07-25-2010 07:39 PM
Tile Baseboard on outside of plastic shower pan at linoleum joint? GaryS Tiling, ceramics, marble 2 07-26-2009 12:39 PM
Removing Vinyl Tile Adhesive from Linoleum The Raven Flooring 3 07-22-2008 08:38 PM
Linoleum Finish Question scubasteve882001 Flooring 1 02-12-2007 07:55 AM
