Old 02-11-2007, 10:28 PM   #1
Linoleum Finish Question
I recently removed laminate flooring tiles that covered my linoleum floor. I used heat to get the tiles up and then Goof Off to get the adhesive off the linoleum, however, the Goof Off removed the finish from the linoleum leaving an ugly, patchy look to the shine. How do I refinish the linoleum to have an even coating and shine? Would buffing it fix the problem?
scubasteve882001 is offline   Reply With Quote
Old 02-12-2007, 08:55 AM   #2
Handyguy
Brik's Avatar
Send a message via Skype™ to Brik
Its probably Vinyl not Linolium. No way to shine it back up. If it IS Linolium then maybe. See here if it really is Linolium http://en.wikipedia.org/wiki/Linoleum. best be is to replace it.
Brik is offline   Reply With Quote
More On This Topic
You love your kitchen floor because of the real tiles laid on it. You like the color, but you like the color even better when the tiles are wet, and they look more vibrant. But read below for some other ways to add some shine to your ceramic or slate... Read More »
In this segment I'm going to talk to talk to you about how to bounce a ball. As you can see I'm on tile today and it's a little tricky cause it has cracks in it. So I really want to practice right in the middle but if you're on hardwood floor or linoleum... Read More »
Hi my name is Jeremiah Johnson; I’m the owner and operator of S&J Cleanaway. I’ll be demonstrating how to remove adhesives from a floor, this can also double for non-stick pads inside of a shower or bathtub or just anything that would... Read More »
Where To Play Jacks
Where To Play Jacks by Expert Village
Hi, I'm Jamie Peterson. I'm here on behalf of Expert Village and I'm here to teach you how to play jacks. Jacks is a really fun game and it can be kind of tricky. But once you get the hang of it it's pretty easy. The first thing you need to do is play... Read More »
A glaze, which provides color and texture, is basically liquid glass the manufacturer sprays, pours, drops or silk screens onto the tile. They then bake or kiln fire the tiles to harden the glaze. Most ceramic tile is glazed, and with so many variations... Read More »
Basement Renovation Question KUIPORNG Remodeling 235 08-26-2008 09:19 AM
Pay GC to construct home and finish it myself? L O N G . . . Badfish740 Off Topic 9 07-27-2007 09:44 AM
Noob question for basement finish electrical dtmbizzle Electrical 16 07-11-2007 08:08 AM
Tile over old linoleum? SeattleDuck Flooring 1 09-22-2006 03:58 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
