-   -   Levelling concrete bathroom floor (http://www.diychatroom.com/f5/levelling-concrete-bathroom-floor-28429/)
eagerinsight 07-19-2005 07:11 PM
My old bathroom floor was a mess. It was a concrete slab and tiled over, in the 70's someone did a bad remodeling job and broke up a large section of the floor to fix the plumbing. They did a poor job of filling the hole with concrete and when I got the house the floor was cracked and rocked under your feet. So I redid the section that was bad, but my mason skills are not the best and the floor is a little uneven. I want to even out the floor but don't want to pour more concrete for a skim coat. Is there something I can pour that will harden and self level itself?
MgMopar 07-27-2005 09:29 PM
Hi
I would recommend a self leveling concrete type product. On a quick search I found this one but there are other manufactures and you should be able to find a similar product in whatever area you are in.
http://www.edisoncoatings.com/html/S...te_floor_t.htm
Even if you don't do the whole floor and you choose just areas of it should work it ok if covered after with your tile
