Old 01-11-2011, 07:12 PM   #1
Levelling a Basement Bath Floor
In the process of a Basement Bath Reno.....I am putting in a 5 Foot Acrylic Shower on one side.....the floor dips about 1 inch from right to left towards a basement floor drain....Overall exposed floor space will be 7x5.....whats the best way to level this out??? Here is what i was thinking...framing the area that will be the floor..(Once the shower comes in i dont want to see that transition in height difference at the bottom)..self-levelling cement,...was thinking putting down Dri-core on top and vinyl on that or just tile right on top of the new cement???????????
zoolou is offline   Reply With Quote
Old 01-11-2011, 07:31 PM   #2
I would tend to put down dri-core first and level that and build everything on top of it since it would be level. Since your 1 inch is not a lot to have to level it should be an easy fix. Once your dri-core is down I would membrane the floor and then tile. Doing this will give you a level floor and good material for which to tile onto with out worrying about broken tiles from moisture or flexing floors.
fixrite is offline   Reply With Quote
Old 01-11-2011, 07:55 PM   #3
wouldnt that method maybe crack any tiles put down...since Dri-core has a tendency to shift???
Old 01-11-2011, 07:56 PM   #4
I would of said yes, if I was not installing the ditra membrane.
Old 01-11-2011, 07:58 PM   #5
It also depends on the size of the tile that is being installed, the smaller the tile the less likely it will have any cracks, regardless of substrate.
Old 01-11-2011, 08:03 PM   #6
i was thinking of actually using the groutable trafficmaster tiles....(wife likes the warmth of vinyl better)..with your method of dri-core underneath
Old 01-11-2011, 08:12 PM   #7
if she is liking the warmth you could add an underfloor heating pad they are not expensive and add value to your home as well.
Old 01-12-2011, 08:24 AM   #8
Has anyone ever used a product called Easymat?? Maybe self levelling cement then roll out the easymat and tile on top?
Old 01-12-2011, 04:26 PM   #9
When i finished my basement i used a self leveling compound from Home Depot. Came dry and you just mixed it in a 5 gallon bucket. You then just poured it out and it leveled out. i had about a 1" difference in the room that was about 5x10. We then tiled over that and the tile has stuck great over the last two years
bethomas is offline   Reply With Quote
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 02:37 PM
Split level walls and floor joists - how are they constructed? jrbutterfly Building & Construction 2 06-09-2009 01:11 PM
Need to expand hot air heat to second floor and basement what are my options rossl56 HVAC 4 01-19-2009 05:53 AM
finishing a basement bath - tie in to ejector pump vent? ajbowman Plumbing 7 04-15-2008 01:09 AM
waterproof basement floor?? patnshan Remodeling 3 09-07-2006 02:58 PM
