Leveling Plywood - Flooring - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-19-2006, 12:13 PM   #16
2x8s 15'?, that floor should feel like a trampaline.
R&D Tile is offline   Reply With Quote
Old 10-19-2006, 12:46 PM   #17
Should I change the joist to 2 X 10's? Should I sister them with 2 X 8's? Remember these houses were built in the 1930's, and wood was expensive. Yes they are 16 inc centered. Thanks, It would be a lot of work to change the beams, but all the houses on this block were built this way, and I am sure nobody has ever changed there beams. You can tell they just fix up the houses on the outside. Will sistering 2 X 8's straighten the problem, and it should also give strength to the beams? Thanks
helpless handyman is offline   Reply With Quote
DIY Chair mat from plywood and carpet tiles jbwaechter Flooring 3 08-20-2009 07:29 AM
Exterior plywood, not secured well enough mt232 Building & Construction 4 07-03-2007 10:34 AM
Exterior plywood mt232 Building & Construction 1 06-25-2007 09:59 AM
Backer board vs. plywood for tile underlayment allpraisebob Flooring 4 01-07-2007 08:44 PM
