Old 08-02-2010, 08:20 PM   #1
leveling an installed floating wood floor
I have a nice floating wood floor. However a section of hallway (3X7 ft) does not have a level subfloor. I get a lot of flex and bounce. Can I inject expanding foam insulation between the floring and subflooring with any success?
woody2 is offline   Reply With Quote
Old 08-02-2010, 08:53 PM   #2
Tileguy
Bud Cline's Avatar
No!
Old 08-02-2010, 10:41 PM   #3
You need to remove the laminate and level the floor and then reinstall the laminate.
You knew that, didn't you?
Ron
Ready to paint the porch! Oil or latex? Leah Frances Painting 8 07-26-2011 08:29 PM
Exterior wood door frame on concrete floor RosenKen Building & Construction 3 06-05-2009 03:23 PM
Old wood flooring - leaks from second floor p<0.05 Flooring 7 05-20-2009 05:41 AM
Garage Floor leveling. Marsharo Remodeling 1 12-30-2005 03:11 PM
