| DIY Forum | DIY Blogs | Photos | Woodworking | Extreme How To | Advertise | Contact Us |
Previous Thread
Next Thread
More On This Topic
Installing the Bottom Board of a Bathroom Vanity
by Expert Village
Ok, so, now all we have left to do, is get our bottom board in. And, what we'll do is, we'll just take this whole door off, see if that will give us enough room, for this to slide in. (Cough) Excuse me. Now, put our hinges back on. And, there we go. OK... Read More »
How to Make a Guitar Neck Shim
by Expert Village
So we've determined that the best, that we need a couple of a hundredths of an inch of extra thickness in order to tilt the angle back. That's about the same thickness as a credit card. So let's go ahead and use a card, a plastic card, to create our shim... Read More »
Setting the Center Pole for a Spiral Staircase
by Expert Village
Hi! This is Weldon Moon on behalf of Expertvillage.com. And the next step in building the spiral is to attach the pole to a fork plate. We have attached in the center of this plate. Then drilled in with a hammer drill, anchored these anchors into the... Read More »
Minor Deck Repair Assessment
by Expert Village
This is an old deck where the joist were bad and this tongue and groove pine was on the deck which I have not ever seen before. This was totally unacceptable. I took up all of the tongue and groove going across the deck (12X17). The joist were all bad... Read More »
How to Find Extra Storage Space at Your House
by eHow.com
If you are at a loss as to what to do with your keepsakes, handed down furniture, year books, children’s toys or holiday ornaments, you should look up and consider your attic. Homes used to be made with stairs that went to the attic. Here children... Read More »
