Leveling A Floor (half Concrete/half Wood)? - Flooring - DIY Chatroom Home Improvement Forum
Old 03-10-2009, 04:46 PM   #1
one determined mama
leveling a floor (half concrete/half wood)?
Ok,
I have a bit of an odd question. I am planning on recovering the floors in my kitchen and den. Now my kitchen is concrete somehow laid over a wood sub-floor (there is basement underneath-not slab) and half of the den is the same (it was originally a porch and a den but was later incorporated into one large den and they added on a sunroom. Right now there is linoleum in both rooms (not matching and in bad shape). I really wanted to have a continuous flooring from the kitchen into the den. There is a bad transition between the wood and concrete and there's sort of a "step down" sloped spot (the concrete section is slightly higher and they attempted to bring the level close..but failed obviously). That would have to be leveled for any sort of non-carpet floor, right?. I can't figure the best way to level this. If it was all wood or all concrete it's be pretty straight forward. I'm guessing I'm stuck with linoleum since it's flexible and wouldn't crack on the weird spot (I'm no pro so I worry about attempting one big piece of linoleum-but I always hear most stick-down tiles don't seem to last). So what on earth can I do here ? Hopefully my description makes some sense
I can draw up something quickly if it would help...
mudpaw is offline   Reply With Quote
Old 03-12-2009, 01:05 PM   #2
one determined mama
So, no one has any ideas? That's unusual here...
Old 03-14-2009, 03:52 PM   #3
Drywall contractor
Rewards Points: 1,070
I'm no flooring expert by any means, but I might (and maybe some others) take a stab at it if you could post some pics. I HAVE leveled some floors, though perhaps not exactly what you're talking about. A drawing might work, but a picture would likely be best.....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 03-14-2009, 04:12 PM   #4
The wood subfloor and the concrete one expand and contract at different rates and move relative to one another at the joint.
You will see evidence of this through the vinyl floor.
Patching the lower side will help but as the two subfloors move relative to one another, you're going to have times when one side is up a little bit and foot traffic can wear through the vinyl at that spot. Consider putting in a "flat" metal (they're usually slightly beveled, but still called "flat") at the transition.
Mudd is offline   Reply With Quote
Old 03-14-2009, 10:50 PM   #5
Registered User
Rewards Points: 5,244
3/4 of both rooms is concrete. Around the cabinets and dishwasher is concrete. In the 1/2 wood den, how many layers of wood is there? Are the floor joists the same plane across the ceiling under the transition area? Is it possible to remove some (1-1/2") of ply or filler at the wood den area, and pour some concrete? How thick is the kitchen concrete,how thick is it at the transition to wood? Maybe bring transition concrete up to level with new (1/2) den? Maybe the 1/2 wood den slopes because it was a sloping porch, and it makes the transition look worse because it's the crown? Be safe, GBAR
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 03:59 PM
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 10:06 AM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 10:14 AM
Self Leveling compound on hard wood floors?? Tbizzy2 General DIY Discussions 3 05-22-2008 12:11 PM
Leveling wood floor helpless handyman Building & Construction 1 10-17-2006 11:06 AM
