Leveling A Converted Garage Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 02-23-2010, 04:13 PM   #1
Leveling a converted garage floor
I am converting a garage into 3 rooms. The old conc. floor has a 1 7/8 inch slope from one wall to the other wall. I wish to level and put down tile. Plan to put down Detra moisture barrier. Question: How to level the floor? Building up a floating plywood floor is out. I want to use solid core doors and because of ductwork I can not trim the doors more than 2 1/2 inches. So thought I would do it with concrete. Goal is to put down 2 inches of conc. at one end leveling it to 1/8 inch depth at opposite end. Have read that one could use leveling conc at min of 1/8 inch. but max is 1/2 inch. Can I stagger mix types to compensate for putting down different thickness? Is cracking an issue with conc. if putting tile over it with thinset? Any concerns with bonding the new conc. with the old? Plan to spread 6 foot by 20 feet sections conc. then do another 6 foot section until done.
Monpz is offline   Reply With Quote
Old 02-24-2010, 11:42 AM   #2
I have a very similar situation, but I don't know the answer. I hope someone who knows will answer.
knighton is offline   Reply With Quote
Recommendations for finishing garage floor? bhpizza Flooring 30 01-28-2011 11:09 PM
Tile a garage floor... Or why not. RegeSullivan Tiling, ceramics, marble 5 10-13-2009 07:46 AM
Refinishing cement garage floor question redpen Flooring 1 05-31-2009 11:07 PM
Leveling a basement floor with a well - help! monichan Flooring 2 03-14-2008 01:31 PM
Staining a garage floor? Ledge General DIY Discussions 5 07-10-2007 04:57 PM
