Old 10-21-2011, 02:01 AM   #1
leveling concrete subfloors for engineered wood installation
This has to be one of the hardest DIY jobs i've done. Basically I am preparing about 900 square feet of concrete subfloors for proper leveling so that I can install my engineered wood floor down properly. Im starting in a room that about 12x12.
I must say I dont know what I am doing. I must have bought 15 bags of 50 lb self leveling powder and my floors are still not leveled. At $35 bucks a bag...well you can do the math. I think I have 5 bags left.
Its hard to describe exactly what the problem is im experiencing but basically if i place my straight edge on the wall to my left starting in a corner my straight edge only tells me what my dips and peaks are for up to 4 feet and not remaining 8 feet that the straight edge does not cover. Now if i move the straight edge over 4 feet i can determine where my high and low points are but im no longer correlated with my previous 4 feet high/low measurement and the last 4 feet high/low measurement.
Im inclined to believe that I need a straight edge that is closer to the length of the room, maybe 11 feet. Its funny all the videos on utube say you need a straight edge but they dont say how long the straight edge has to be.
Overall the floors are not messed up to the point that i need to chip up any level compound it seems like i will measure a low, fill in the low and the low is still there next time i measure and i think this is happening because im not laying down the straight edge like i did the first time so my low/high measurement are changing on me if you kinda understand what im getting at.
Any advice?
robismyname is offline   Reply With Quote
Bamboo on modified concrete pad jhanson Flooring 0 10-08-2011 12:58 PM
Installing 9mm bamboo over 9mm wood floor and concrete hellobritt Flooring 4 08-30-2011 10:35 PM
Help on tool selection for leveling concrete slab Wohn Flooring 3 07-11-2010 03:03 AM
Wood to Concrete Block bmancanfly Building & Construction 7 09-22-2009 04:45 PM
Wood to Concrete without Drilling MattStata Carpentry 1 04-19-2006 05:16 PM
