Leveling A Concrete Slab For Laminate - Flooring - DIY Chatroom Home Improvement Forum
Old 05-03-2012, 10:45 AM   #1
Leveling a concrete slab for laminate
First of all the basement is dry, I have had a 4x4 piece of 6 mill tapped down there for 2 weeks and it is bone dry. Now, the slab is unflat as well as unlevel. Its highest spot is in the middle then it slopes about 3/4" over 10 ft left and right. It also has some valleys and ridges. What i was planning on doing, is laying down 3/4" rigid foam, taping seams, and then laying some 3/4 ply, and tapcon it all down. I have read of people using this method to level the floor. My question is do you think it would take enough of the unflatness out to lay laminate? I really wanted to avoid doing the self leveling underlayment. It will double my cost.
yamahamer342 is offline   Reply With Quote
Old 05-03-2012, 11:07 AM   #2
Rewards Points: 13,740
Anything flat you lay down will just follow the level of the floor.
Laminite or any type flooring could care less if the floor is not level, it's the flatness that matters.
Old 05-03-2012, 12:48 PM   #3
I understand it wouldnt correct any leveling issues, but the flatness? There are small ridges and valleys in the slab. I figured laying the foam and 3/4 ply would take most of that out. If not, I will just go ahead with the self leveling underlayment.
Help stone over concrete slab Johnnyquest Flooring 0 05-20-2011 03:36 PM
Concrete slab to foundation work tntgarv Building & Construction 3 02-28-2010 12:23 PM
Removing concrete slab on 3rd floor bathroom NowItsShowtime Flooring 2 03-26-2009 02:17 PM
Remodel over sloped concrete slab PSL_Hokie Building & Construction 11 07-11-2007 05:14 PM
cracks in concrete slab causing home sale to fall though! help! bp13 Building & Construction 14 07-04-2007 12:32 AM
