Leveling Cement Basement Floor For Tiling? - Flooring - DIY Chatroom Home Improvement Forum
Old 03-15-2013, 12:07 PM   #1
Braddiy's Avatar
leveling cement basement floor for tiling?
I have installed a Bathroom/Laundry room in basement, but did not realize the cement floor is very un-level from exterior wall to main drain in room, it is out of level by 1 inch in a six foot span, the area were i installed tub was level. i want to tile floor with ceramic.
Is there an easy way to level floor (cement is painted and flaking in some areas do i have to remove all paint first). The tub is already installed, can i level cement up side of steel tub about 1 inch. or can i thicken mortor for tile installation.
thinking ahead is not my strong suite (dammitt)
Tub shower surround is already tiled so removing tub is not an option.
pictures available in photos section under braddiy
leveling cement basement floor for tiling?-335621_159298450828405_100002447537959_288410_823616525_o.jpg   leveling cement basement floor for tiling?-328602_166150803476503_100002447537959_311872_1675937215_o.jpg   leveling cement basement floor for tiling?-333122_158629984228585_100002447537959_285597_1743605319_o.jpg
Braddiy is offline   Reply With Quote
Old 03-16-2013, 10:11 AM   #2
Rewards Points: 216
yeah, you have to get at least most of the paint up. for that small of an area, i would use thin set to level it up, don't do it in one shot. do it in layers.
Fix'n it is offline   Reply With Quote
Old 03-16-2013, 10:13 AM   #3
Rewards Points: 216
oh. i would not go right up to the tub. use a thin spacer.
The Following User Says Thank You to Fix'n it For This Useful Post:
Braddiy (03-16-2013)
Old 03-16-2013, 10:15 AM   #4
DIY staff
Rewards Points: 7,174
Once again, the paint needs to be removed---I would use self leveling compound---thin set shrinks as it sets---using it for leveling is a tough job---could be done, I suppose. but not the best way.
Old 03-17-2013, 10:33 AM   #5
Rewards Points: 216
i have used self leveling. perhaps i was doing it wrong, but the stuff, to me, is not all its cracked up to be.
that is why its is done in layers. at least a day before each layer. no more than about 1/4" each layer.
Old 03-17-2013, 12:20 PM   #6
DIY staff
One hour is the set time for Jifset---Perhaps you used a different product----I can pour and set in a short time---
Any self leveling compound that I have used is a chemical set ---usually 20 minute---
Tags
cement floor , floor , tiling
Basement Floor Leveling Help brokenbricks Flooring 2 08-15-2010 06:34 AM
Drywall or studs first before self leveling cement sandoy1121 Flooring 0 07-26-2010 07:50 PM
self leveling cement questions gramps416 Flooring 0 07-05-2010 10:36 PM
patching holes in basement cement block wall jhiner Building & Construction 3 06-02-2010 04:03 PM
cement falling into basement from cement porch above. Betsy G Building & Construction 3 10-21-2007 01:53 PM
