Lease Does Not Permit Wood Floor, Is This A Good Way Round? - Flooring - DIY Chatroom Home Improvement Forum
Old 04-12-2010, 12:04 PM   #1
lease does not permit wood floor, is this a good way round?
Hi
I was wondering what advice any of you might have.
I just purchased a flat recently (leasehold and share of freehold), and I want to put wood flooring yet the lease says that I am required to "fully cover and keep covered the floors of the premises with carpet and underlay". I understand this is to prevent sound affecting the neighbours below. The current carpets and underlay do transmit quite a lot of sound anyway (I can also hear the footsteps and radio from upstairs), so I am thinking, to ensure that I do not disturb the neighbours while still abiding by the lease to install the following:
1. Carpet tiles directly onto the floorboards (cheap, thin, hard as they have rubber backing, and provide some sound insulation) and I abide by the lease requirement of having "carpet"
2. Tredaire Technics 5 underlay (very expensive, excellent sound insulation) and I abide by the lease requirement of having underlay
3. Engineered click-system wood floor as a floating floor
Now I think the carpet tiles are not really 'spring' enough to create the 'bounce' effect, and the underlay is one of the best for sound absorption and surely will all these layers, the sound reduction is better than the cheap underlay/carpet that is currently in place?
Its expensive, but I don't want to annoy my neighbours, and I don't want to breach the lease. What do you guys think in terms of installation, how it will feel, and sound-insulation-wise?
monty82 is offline   Reply With Quote
Old 04-12-2010, 12:42 PM   #2
Rewards Points: 77
This seems like a lot of work and not much reward. i.e. I don't think it's really going to make a different in sound when it's all said and done. Is there insulation in between the floors currently? Don't know if this is feasible or not but I'll just throw this out there as a idea. What about drilling a hole in the subfloor (after you remove the carpet) and filling the space with some sort of sound absorbing insulation?
nateo is offline   Reply With Quote
Tags
underlay , wood floor
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 02:59 PM
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 09:06 AM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 09:14 AM
Brick and wood flooring jhughesfam Flooring 1 08-18-2007 03:29 PM
Wood to Concrete without Drilling MattStata Carpentry 1 04-19-2006 04:16 PM
