Old 06-02-2012, 07:43 PM   #1
leaky floor / wall around enclosed porch
i have a very old house with an enclosed porch that was at one time an open porch. the inside walls around the perimeter of the porch floor have brown water marks where water from rains has wicked up into them from outside. the edges of the porch floor on the outside of the house are visible as they commonly are in these porch conversions. i want to know if anyone knows how to seal this up so that the water stops coming into the walls. i am also afraid that the edges of the floor on the outside may not have enough of a downward grade to the outside to encourage water runoff. water also collects under the screen door leading to the outside steps. if anyone can help, i'd appreciate it! thanx!
labgirl is offline   Reply With Quote
Old 06-02-2012, 08:35 PM   #2
Pretty common problum, post some pictures.
Look foward to rotted bottom plates, rotted bottoms of the studs, rotted sheathing. Oh goody.
Old 06-02-2012, 10:22 PM   #3
actually, this has been going on for as long as i can remember (we've been here 21 years ) and it hasn't ruined the floor yet...as for underneath, there is nothing underneath...dirt and a crawlspace, the basement doesn't extend under the porch...it's built over the ground. i just figure that it's eventually going to rot the wall or allow access to insects.
Old 06-02-2012, 10:32 PM   #4
Super Moderator
Pictures would help--often porches are enclosed without much thought about the design---so leaks and rot are common
Tags
closed in porches, leaking floors
Adding to Concrete Porch + Steps? 99altrade Building & Construction 8 08-01-2011 01:14 PM
Enclosed Back Porch Project drussoli General Discussion 3 06-15-2011 05:17 PM
Unique framing condition: Enclosed Porch clemson726 Building & Construction 1 10-19-2010 01:01 PM
Help- Need to find a good floor for totally enclosed porch glamgirrl Flooring 2 07-15-2010 10:43 AM
Enclosed Porch Floor Joists detanner Building & Construction 5 01-27-2008 07:31 AM
