Leaking Toilet Messed Up My Floor/Can I DIY? - Flooring - DIY Chatroom Home Improvement Forum
Old 08-14-2012, 06:22 PM   #1
Leaking toilet messed up my floor/Can I DIY?
I recently moved into an apt and noticed that the toilet was leaking. There seems to be a good amount of mold underneath the tile, but I can't see it so I am not too sure.
My question is, can I fix this myself? The wood sub floor, cement, and the tile. How hard of a job is this? My experience is limited but I am a decent wrench if that means anything.
madarussia is offline   Reply With Quote
Old 08-14-2012, 06:27 PM   #2
Rewards Points: 13,300
What may look like a simple job to you, would require a lot of special tools and the whole floor would have to be redone.
I'd go nuts if I ever cought one of my tennats attempting to do this.
Old 08-14-2012, 06:42 PM   #3
Thanks for the reply Joe, I called the agency and they are going to come out and inspect the damage.
Old 08-14-2012, 06:48 PM   #4
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
I did this in my own home. I pulled the toilet, replaced some of the subfloor, cleaned off the tiles and reused them, but I wouldn't try it if it wasn't mine.
A repair like this is seldom as easy as it seems, and it's always a "never-really-know-what-you're-getting-into-until-you-tear-it-apart" situation.
They often snowball into something bigger than you bargained for.
Edited to add: Oops, slow typist.
Strangely Leaking Toilet... OhmZoned Plumbing 4 01-14-2012 12:55 PM
Can't figure out where the toilet is leaking??? Interior? CostcoMan Plumbing 11 04-13-2010 02:47 PM
Toilet leaking at the base on floor John24689 Plumbing 4 10-19-2009 09:03 AM
HELP - Seriously leaking toilet JAR Plumbing 3 11-03-2008 05:28 PM
Water leaking into septic pipe below toilet Gramps Plumbing 1 09-14-2008 10:54 PM
