Old 09-06-2012, 02:44 AM   #1
Leak Under Laminate Flooring
Hello,
I have a leak under my laminate flooring in my basement. I have been running a dehumdifier for a couple weeks and get full buckets every day. I Think there may be a old floor drain somewhere which might be causing the problem. Any suggestions?
Thx
matt41129 is offline   Reply With Quote
Old 09-06-2012, 10:49 AM   #2
First you have to remove the flooring, by now there will be mold under it.
Then find the leak and cut out that section of concrete and fix it.
If it turns out to be old copper supply lines, it may be time to rerun them above the floor. At some point they were going to fail.
Old 09-06-2012, 05:19 PM   #3
An old Tradesmen
Moved to flooring forum.
Old 09-06-2012, 07:32 PM   #4
JetSwet's Avatar
I guess didn't like this forum? Lol it's much quiet over there less entertaining.
JetSwet is offline   Reply With Quote
Old 09-06-2012, 07:38 PM   #5
An old Tradesmen
I think he was using his work's internet service, and is a third shift person.
laminate flooring over laminate flooring bowbender6 Flooring 6 07-04-2012 10:27 PM
Laminate Wood flooring for duplex jukeboxpunk Flooring 16 06-23-2012 05:39 AM
Is there a durable laminate flooring for kitchens? samalex Flooring 5 11-03-2010 03:55 PM
Basement Flooring: Laminate material atm Flooring 1 06-30-2009 11:34 AM
Laminate Flooring Questions... sootybuttercup Flooring 1 08-13-2006 09:35 PM
