Leak Problem - Flooring - DIY Chatroom Home Improvement Forum
Old 06-25-2012, 06:25 PM   #1
Leak problem
We have a carport that was turned into a den we had noticed that
some of the carpet was getting wet when it rained. We tore up the
carpet and padding we found the wood used to build the floor was
also wet we have take that part out.. We found that it looks like
that between the floor and wall that was where the leak was. What can we do correct this poblem?
JayKerri is offline   Reply With Quote
Old 06-25-2012, 06:26 PM   #2
Rewards Points: 6,652
Can you post pictures of what the grade looks like outside.
Old 06-25-2012, 06:59 PM   #3
no but it is flat ground with the front of the house and we did notice some roots
Old 06-25-2012, 07:12 PM   #4
Still need pictures, so others can see what you are dealing with. My guess I would say, that it was not properly done, is why you are getting water intrusion, which means a grade issue up to the old pad. The wood is most likely all rotted, that was used as plates against the raw concrete.
Toilet leak continues after replacing parts Oldern Plumbing 0 03-29-2012 11:15 AM
Possible small gas leak in black iron pipes WillK Plumbing 4 01-18-2012 12:07 AM
Roof leak nightmare..... it won't stop amandat37 Roofing/Siding 52 04-22-2011 01:47 PM
Roof leak around my chimney - update GlennAble Roofing/Siding 3 11-05-2009 07:24 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
