-   -   Leak problem (http://www.diychatroom.com/f5/leak-problem-148241/)
JayKerri 06-25-2012 05:25 PM
Leak problem
We have a carport that was turned into a den we had noticed that
some of the carpet was getting wet when it rained. We tore up the
carpet and padding we found the wood used to build the floor was
also wet we have take that part out.. We found that it looks like
that between the floor and wall that was where the leak was. What can we do correct this poblem?
gregzoll 06-25-2012 05:26 PM
Can you post pictures of what the grade looks like outside.
JayKerri 06-25-2012 05:59 PM
no but it is flat ground with the front of the house and we did notice some roots
gregzoll 06-25-2012 06:12 PM
Still need pictures, so others can see what you are dealing with. My guess I would say, that it was not properly done, is why you are getting water intrusion, which means a grade issue up to the old pad. The wood is most likely all rotted, that was used as plates against the raw concrete.
